Kaptain Krunch
Pro Junk Collector
So, spring is here and i need to finish my KZ400 kart, its almost there, just needs the finishing touches, brakes, a little tweaking on the clutch linkage, paint, and a little engine work. Today i made a gas tank for her, out of a fire extinguisher.
Over april break i'll be getting a buncha parts from my dads cars, i need a master cyl, some switches, a starter motor for reverse (possibly), and probably some other stuff. Then i should be able to bring it into the shop at school, and do a buncha little stuff on it, im planning on junking these CV carbs, for a 34mm mikuni roundslide, then i need to do tune up the engine, adjust valve lash, chain tension, new plugs, oil change, etc.
Anyways, heres some pictures of the tank, came out alright, i used a threaded end from some gas pipe as a inlet/cap. For the output i just welded a bolt on that fit a on/off petcock i had.
