Wheel/Tire Replacement - Help!
Kristajoy15
Go kart rookie here, trying to work on a kart I bought from the neighbor and need to replace the rear wheels. Problem is, I’m STRUGGLING. I know the tire size and all, but I’m clueless about the rest. Anyone have advice on what to order and where to find what I need?
I’ve added pictures for reference. Thank you!
⬆️ That is 1 to 1 replacement wheels that is, if you want to keep the tires/tire size.
What kart do you have?
Kristajoy15
Just a basic frame with a new Predator. Nothing fancy.
Atlanta, GA
Fancy is as fancy does. That chain will not stay on those sprockets misaligned like that, or maybe it will and you have a magic kart.
Measure the wheel's bolt pattern this way. You can also measure the the front edge-to-front edge of the holes (my photo markup in green) which will give you the same results and it will be much easier....
By the way, you didn't show us any catastrophic damage to the wheels or a reason why you wanted to replace them. Are we missing something?
Photo #3 looks a bit suspect, like a wasted wheel bearing but ...?
They might be "ugly" to you but massaging them with a bit of sandpaper and giving them a quick squirt with spray paint does a splendid job. . .
