Daily WTF?
BrownStainRacing
Real trucks have Detroits, White, Cummins or Cat power.
I agree, I got grandfathered in for CDL class A in 1990. Been driven trucks for a mile or 2.
That's what you need for a daily driver to haul the big gals around.
I'll stick to my pos, brake booster, 390k mile, sbc 1/2 ton truck. 😆 🤣 😂 😹.
BrownStainRacing
Not again!!!!!! I wanna refund.
I lied.
I got my chauffer license in 88' when working for a furniture company, then went to work for a trucking company in 90' and then got grandfathered in in 93' when cdl came out.
Sometimes I forget how freaking old I really am, 🙃 😅 🙂 😐 😪
Crankshaft endplay might cause issues with side cover seals.
I like to use the Dorman exhaust manifold stud kit from the local parts store for side covers on small blocks. The small blocks need M8/1.25 studs. To put the TC back plate on I used washers behind the backplate and yes I had to cut the ends of the studs off flush with the nuts to use the backplate.
That is as fine of workmanship as I have ever seen!
Might even be as good as this:386472545_10228117250509398_5896557175443659990_n.jpg
...At which point the crankcase side cover decided to part company with the crankcase. Bolts were sheared off and some were just backed way out...
Did you do a proper autopsy?
The backed-out bolts may have taken threads with them which is mechanical separation or in the same vein as being sheared off. If that is not the case, they could have worked themselves out (unscrewed) gradually due to the vibrations and oscillations and then the rest of them went boom with the overpressure.
Instinctively, to me, this was an engine explosion before I saw post number 13 (unlucky #13) ;). All engines are air pumps and we dismiss this truth to our own peril. This was neat to read, thanks for sharing!
