Hey guys, new to the forum.
I picked up a Murray Red go kart early this week and am looking for some guidance/advice.
Biggest issue I have is a traction issue. The kart has been basically unmodified besides the motor as best I can tell. The dead axle seems like a very common config on less expensive karts and I have to suspect they generally work well.
However, I can't get power to stay planted anywhere. Pavement (I know these are not street tires but still), I will almost instantly spin the tire until traction builds. Grass is very similar, I have to ease into the throttle so as not to spin. Even then all it takes is a gentle slope or a patch of grass taller than 3 inches to stall the kart and spin the wheel. I have a few bare patches of clay in my yard and even they dont give the grip I'd expect from these tires, I just dig a hole in no time.
My question is, is there a better configuration for me to use to grant more grip? Different sprockets for different gear ratios? Turf tires? Both? Something else entirely? It sure is fun while it's moving but significantly less fun once it stalls and I have to get out to pull it back to where I can get grip again. As it rides now I am very unimpressed and if I can't remedy this issue it'll have to go in favor of something with a live axle.
Second question is steering. I have great steering to the left, enough to also stall the kart unless its really moving. To the right is mostly a lazy curve to the right. This is intended to be driven by my kids and that wont due. I don't see anything beyond the physical limitations of the swing of the wheels that should stop it from turning well to the right, so why can't I get a good right turn? Is this type of issue remedied with the tie rods, by adjusting them to where center at the wheel is started further to the left?
Specs are as follows;
Predator 212 non-hemi (2 days old)
60t axle sprocket
10t clutch sprocket.
Carlisle Super Lug rear tires 13" tall
Thanks in advance!
60t axle sprocket
Thanks in advance!
