1983/4? Honda Odyssey FL250/340fan HELP!
JoeC
Hello I just picked up a very nice and clean fl250
JoeC
Nice go kart, and it's probably the carburetor is not tuned properly
Okay thanks... just want to also say I almost have to feather the throttle to hit a sweet spot before it like to take off too.
colestreasures
Kentucky
I believe it is your carb , needs a good adjustment/fine tune on it. And when adjusting a carb like that you have to take your time, it takes a few seconds sometime for the adjustments to catch up and level out.. your already running pretty fast or sounds like it in your video, before you start it turn the mix in till it bottom out then back it back out about 1-1/2 turns should be close, then start it up and tweek it from there , just remember do this in small increments and allow it to catch up before you turn it anymore , or you will miss the carbs sweet spot and have to start over. JMO
Cole
Idle sounds way too high first off. Secondly it also may be suffering from clutch/belt compatibility issues. The exhaust system can also be hurting drivability and moved the power band the wrong way. In other words Good Luck!
:feedtroll:
Axx3d
MN
Axx3d
MN
No.. The pow was directed at the Batman n Robin reference.. Sorry for the confusion.
Where in this frigid state of ours do you live?
JoeC
Minnetonka suburbs, but I have 40 acres of land up north and ride the pipeline a a lot.
