can i use 6.5hp parts
r_chez_08
Should be in the shop...
Cornwall, UK
Doubt it mate, 6.5 and 8hp are different block sizes and like a different series of parts as far as I know.
Gx305???
The only reliable oem aluminium flywheel that you can get for a gx160/200 is one from a gxv160 (possibly other gxv) flywheel brake model. Believe me, I researched for way too long, trying to save a buck or two, and these gxv160 ones are rarer than rocking horse dump, except on karting sites
Ok clearly it was a typo.
OP-I reckon you are just going to end up buying the upgrade parts you want to get.
Im thinking in this case there is just no easy way around it. We talked on the other thread about machining a flywheel, next time come off hand what you want and for what.
r_chez_08
Cornwall, UK
Waste of time imo if aftermarket parts are available. Getting the taper perfect, getting the balance perfect, getting timing perfect and finding the right magnet would take a while, and then look at the cost for a massive chunk of aluminium, or even steel. Not cheap!
Cheers,
Rob
mafi888
dude i can not listen before these parts of Honda but may be possible that its modify part of the Honda which i have no knowledge..But any body tell me that what is the specification of this part?
r_chez_08
Cornwall, UK
Mate, not being funny, I don't have a clue what you are trying to get across! If English is not your first language, then I apologise, but if not, please make more of an effort.
Food for thought.
Cheers,
Rob
Food for thought.
Cheers,
Rob
He is from Pakistan, but I agree that he should use better english.
Mafi888, what you can do is use google translator to translate from Urdu? to english and then paste it here
