.083 is very thin material especially for something as small as 1" square tubing and a ladder style frame.
While I agree that larger tubing would be appropriate for a ladder frame, .083" ain't
that thin, relatively speaking. Actually, if it were for a space frame, I would call that too thick!
Round tubing of the same size is stronger and weights less but you might want to consider .095 or even .120. Round tubing is harder to work with.
It's better to use larger diameter tube with a thinner wall, than smaller tube with a thicker wall. Pound for pound, the results are stronger. While round may be marginally lighter and arguably stronger, it's a royal PITA to work with if you do not have the appropriate tools, such as a bender and a notcher. Square tube is much easier to deal with for the average DIYguy, as cuts can be mitred easily, even by hand.
If this is your first project, and you do NOT have tools or experience specific to round tube, I would suggest square tube in the 1.25" to 1.5" range, with a wall thickness in the 0.065" to 0.080" range.
IMHO, 0.120" wall is just too heavy for an "average" kart.
