Closed Thread
Old 08-19-2010, 08:43 PM
Stormn94 Stormn94 is offline
Junior Member
Default Bad Clutch?
I have a Briggs and Stratton engine I think it is around 5 hp. Then mounted on it I have a centrifugal clutch... When the engine gains rpm and the clutch has sufficient speed to engage, it won't engage. It is a fairly new clutch. anyone know whats wrong?
thanks all,
Nik
Old 08-19-2010, 08:47 PM
Russ2251's Avatar
Russ2251 Russ2251 is offline
AZUSA LAWN-BOY E
Is clutch housing heating up? Smoking?
Those that can, do. Those that can't, buy a Predator!
Old 08-19-2010, 08:48 PM
Junior Member
It doesn't even heat up, which really surprises me.
Old 08-19-2010, 08:56 PM
r97's Avatar
r97 r97 is offline
Measure twice cut once
your clutch is prob stuck, or the springs are too tight. if that doesn't work make sure your engine is spinning at at-least 3000 rpm
Old 08-19-2010, 09:05 PM
Junior Member
the spring does seem a bit tight... do you know how i can adjust it?
Old 08-19-2010, 09:09 PM
r97's Avatar
r97 r97 is offline
you could either pull out a couple coils on the spring or just buy new springs from some place like bmi
  #7
Old 08-19-2010, 09:15 PM
Junior Member
This clutch has one continuous spring... how would i pull a couple coils wouldn't that make it tighter?
  #8
Old 08-19-2010, 09:20 PM
r97's Avatar
r97 r97 is offline
oops sry about that yea you prob need a new spring unless someone else has a quick fix
  #9
Old 08-19-2010, 09:21 PM
Junior Member
Is there any way to stretch the spring somehow do you know?
  #10
Old 08-19-2010, 10:12 PM
r97's Avatar
r97 r97 is offline
maybe, only way to find out is try it!
  #11
Old 08-20-2010, 07:22 PM
Kenny_McCormic Kenny_McCormic is offline
Kartless....
What kind of clutch is it? My bet is its jammed up or rusted shut, take it apart and make sure all is well.
  #12
Old 08-20-2010, 08:11 PM
r97's Avatar
r97 r97 is offline
i mentioned that alredy, and thought that when he jumped stait on the spprings, that he had checked if it was stuck but maybe not, im not sure
  #13
Old 08-23-2010, 09:59 PM
Junior Member
I am working on taking it apart right now, will let you all know what I find. Thanks for the suggestions.
  #14
Old 08-23-2010, 11:21 PM
Blazkowiez's Avatar
Blazkowiez Blazkowiez is offline
Kart Aficionado
What are the size of the tires on this kart and what size sprocket/pitch count are you using to compliment this clutch and 5hp Briggs?
I'd be curious to see your ratio assuming your engine is revving to the rate it would need to engage fully. The spring may not be the issue.
gokartrepair.com. Family owned and operated in Houston for 40 years. Parts-Service-Advice
  #15
Old 08-30-2010, 07:49 PM
Junior Member
I'm pretty sure its not the ratio because it was working just fine... the clutch doesn't even begin to engage, which leads me to believe it has internal problems.
Closed Thread
