Closed Thread
Old 07-09-2010, 08:48 PM
Aleks976 Aleks976 is offline
Junior Member
Default How To Remove/Transfer A Centrifugal Clutch From Engine To Engine
Hi, I have a 5.5hp Honda Engine, and I have a 6.5hp Engine that has the same sized shaft (3/4). I was wondering how to remove the Centrifugal Clutch From the Honda Engine and how to put it on the other engine.
Thanks
Old 07-09-2010, 09:13 PM
Junior Member
I thought it would be that easy, I just dont want to break / damage the clutch
Old 07-09-2010, 09:58 PM
Cam's Avatar
Cam Cam is offline
Nz Petrolhead
Easy is matter of opinion, you might have to use pullers, not very often do they slide off!
Goes for pulleys as well, there is a dimple in the end of the shaft where you locate the centre spigot of the puller.
Cheers, Cam
Closed Thread
