Closed Thread
Old 05-01-2010, 03:33 PM
r_chez_08's Avatar
r_chez_08 r_chez_08 is offline
Should be in the shop...
Default Briggs 3hp and ?Honda gx100?
i have aquired these engines for 10 and was wanting to get them running. the briggs seems reasonably complete except airfilter, recoil and sparkplug cap. the engine that looks like a honda gx100 is complete except recoil, recoil cowling, ignition coil and plug, and filter. i am looking at the briggs first, and it has good compression, should be getting fuel, but i cant get the coil to give me spark. it gives a bloody good shock when touched whilst turned over tho! any ideas to get spark without the cap? and also what is with the carby?
Edit: do briggs have caps? as i saw a pic on google images of 1 like mine.
My process of thought:
Anyone can drive a fast car, few can drive a car fast.
Old 05-01-2010, 04:40 PM
anderkart's Avatar
anderkart anderkart is offline
Hey I like your Honda, Its an older G-series made before the GX series came out. The flathead G-series came in 8 different models ranging from 3.5 to 10hp. These old Honda's were pretty good engines that won a lot of kart races back in the 70's/80's. I've still got a running 10hp, G-400 I raced on my kart last season.
You'll find some Honda G-series info here: http://world.honda.com/history/chall...77themeengine/
Here's all the G-series owner manuals, they might help ya figure out what model you got there : http://www.honda-engines.com/engines...anuals/own.htm
Old 05-01-2010, 04:52 PM
solomon solomon is offline
You probably have points ignition. Their should be 3 wires coming from your coil , Spark Plug Wire, Ground Wire, and Points Wire. The points wire goes down behind the flywheel. Pull the flywheel and sand the points a bit, and check the gap.
Old 05-01-2010, 05:17 PM
r_chez_08's Avatar
Thanks I will look tomorrow
Old 05-01-2010, 05:19 PM
Kaptain Krunch's Avatar
Kaptain Krunch Kaptain Krunch is offline
Pro Junk Collector
I'm about 90% sure u dont have points. If your getting shocked, there is a good chance you just have a bad plug.
The carb is very unique, it sucks gas directly from the tank, through pickup tubes. It has a diaphragm inside that can go bad, so you may have to replace that for it to run well.
"If you want, I can teach you how to make a bomb out of a toilet paper roll and a stick of dynamite"
Old 05-01-2010, 05:33 PM
r_chez_08's Avatar
Thanks kk does any plug work because I have a spare plug which is the same thread but bigger
  #7
Old 05-01-2010, 06:10 PM
Kenny_McCormic Kenny_McCormic is offline
Kartless....
A spark plug is $3, it isn't worth messing with. I have seen bad plugs do STRANGE stuff.
  #8
Old 05-01-2010, 06:12 PM
r_chez_08's Avatar
I know just I have a spare plug and there is no point me going to get one if it will work, although the White bit on the end is longer.
  #9
Old 05-01-2010, 09:29 PM
looks to me like a points motor.....
  #10
Old 05-01-2010, 09:31 PM
Look at the coil again
  #11
Old 05-02-2010, 01:44 AM
r_chez_08's Avatar
I will see if it is points later. If it is that may be it's only problem but it may need a carby clean.
  #12
Old 05-02-2010, 01:50 AM
r_chez_08's Avatar
@anderkart; thanks I am 99%sure the Honda is a g100 but only 2.2 or 2.5hp
  #13
Old 05-02-2010, 07:26 AM
r_chez_08's Avatar
Dedinantly g100 83cc because it says on the block
  #14
Old 05-02-2010, 04:42 PM
robbie robbie is offline
I agree with Kaptain Krunch on the spark plug. If it gives you a strong shock, you should get a spark. Don't bother with the points until you are sure you have a good plug.
You can hold the wire so the end is a couple of millimeters (1/8" for my fellow Americans) from your block or head. Pull the rope and you should get a spark between the engine and the wire. If you get a spark without the plug, try a different plug and see if it sparks across the plug gap.
  #15
Old 05-02-2010, 05:17 PM
r_chez_08's Avatar
Ok thanks. I think it is points, as it has some extra wires
  #16
Old 05-02-2010, 05:25 PM
Kartless....
Its a points engine, electronic ignition coils are easily identified by the electronics portion in between the leading leg of the coil and the coil itself.
  #17
Old 05-02-2010, 08:15 PM
I like karts's Avatar
I like karts I like karts is offline
Rotary Power!
Quote:
Yeah I had one that had a little bit of rust on the insulator which was actually shorting the plug out because the spark was jumping from the boot onto the rust. I wiped it off and it was better. easiest fix ever
  #18
Old 05-03-2010, 12:43 PM
r_chez_08's Avatar
Okay, I found a coil for the Honda. It looks in better condition than the Briggs so I am going to try and get it working first as I have a coil. I get good spark, but no go. I have cleaned the head. It is completely unscored, and I have tried cleaning the carb, but I an not really sure how? Any advice?
  #19
Old 05-03-2010, 12:56 PM
KieranM's Avatar
KieranM KieranM is offline
Doin It!!
is it getting fuel into the chamber?
  #20
Old 05-03-2010, 03:13 PM
IS it holding compression?
Closed Thread
