Closed Thread
Old 03-16-2010, 08:24 PM
LongBowSniper LongBowSniper is offline
Junior Member
Default What tubing to use on a cart frame
Hello,
I was wondering what type of tubing to use to build a frame for a go cart... And wheres the best and cheapest place to buy it?
Thanks,
Ben
Old 03-16-2010, 08:50 PM
khank1995 khank1995 is offline
try menards, lowes, homedepo
Old 03-16-2010, 09:51 PM
Blazkowiez's Avatar
Blazkowiez Blazkowiez is offline
Kart Aficionado
Most towns have steel supply stores besides simple home repair warehouses that have exceptional prices on steel in 20ft sticks, additionally for most places if you order a certain amount, say over 200 dollars, they'll ship and cut it in quarters or half for free.
gokartrepair.com. Family owned and operated in Houston for 40 years. Parts-Service-Advice
Old 03-17-2010, 12:12 AM
vgk vgk is offline
Are you looking at square or circle? Aluminum or steel? This will help and are you close to a steel supply shop or just what khank said?
Old 03-17-2010, 04:42 PM
Yeah try your best to find a steel shop online or the phone book
Old 03-17-2010, 07:22 PM
mrfreyguy's Avatar
mrfreyguy mrfreyguy is offline
Buggy Almost Done
I would try to stay away from the menards and lowes stuff. It's not meant for structural purposes and it's not the highest quality.
  #7
Old 03-18-2010, 04:21 AM
Doc Sprocket's Avatar
Quote:
Amen, brutha! I had a coworker stop by Home Depot and get me a length of angle for a fire escape railing I had to repair. I couldn't believe the hunk o' crap he handed me!
They also charge far too much for what you get.
  #8
Old 03-23-2010, 05:04 PM
Hybrid Hybrid is offline
well with all that being said, not trying to threadjack but i'm more adding to the question -
Which would be better for to use considering strength/weight
-Aluminum
-Steel
How thick?
I have been wondering the same thing =D
  #9
Old 03-23-2010, 05:54 PM
mrfreyguy's Avatar
Buggy Almost Done
18 bucks for a 8ft piece 16 gauge square tubing! Lowest prices at lowes? I call BS
To answer your question hybrid steel would be better for a kart application. Thickness depends on what your building your cart to do.
  #10
Old 03-23-2010, 06:16 PM
Aluminum is likely to cost more, and many of us are not equipped to weld it. On the other hand, done properly it would be very, very cool, and lighter, too!
  #11
Again not trying to thread jack but personally i'm trying to make an off road cart, not a crazy rock crawler or anything but something a bit more than your average back yard cart
  #12
Old 03-23-2010, 06:33 PM
mrfreyguy's Avatar
Buggy Almost Done
Steel would probibly be what you want then. It's what I'm using for my lifted mower and buggy.
  #13
Old 03-23-2010, 06:42 PM
Steel is also easier to weld? I have a welder but haven't tried it out yet.
Also, What about thickness, Schedule 40 pipe? Best cost/strength ratios?
  #14
Old 03-23-2010, 06:52 PM
Imbo Imbo is offline
Young Mechanical Genius
also just throwin this in there...if this is your first kart and/or your not muckmof a metal worker i would advize using square tubing...much easier to weld and work with....however i think that circular looks to an extent somewhat cooler.
It is a fact that every teenage boy comes home, goes to his room, locks his door, turns on the computer, puts on his helmet and welds.
  #15
Old 03-24-2010, 05:13 AM
modelengineer modelengineer is offline
Lord of the noise
Aluminium is a very very bad idea for a frame. Steer clear.
You want tube, not pipe. Pipe is very heavy and not very strong for it's weight.
Andrew
GS500F powered...
  #16
Old 03-25-2010, 07:48 PM
Junior Member
Ok sorry it took me so long to get on i havent really had time lately... Im looking for round steel... I have a guy whos going to weld it for me and i hope to have him teach me aswell
Closed Thread
