Go Back   DIY Go Kart Forum > Building Plans And Advice > Electric Projects
Closed Thread
Old 02-02-2010, 05:39 PM
pmwoodward3 pmwoodward3 is offline
Junior Member
Default PVC go kart, with fiberglass
So i've had the idea to make a go kart for a while, but i never had the money or the time. But now i do. So my idea is to make a simple go kart frame from PVC then rap it in a couple of layers of fiberglass for extra strength. So today i got all the PVC parts and fiberglass i need, but now im stuck on what kind of engine to get. I don't have alot of money to spend on it, so im looking to find an engine. Im trying to make a fast go kart, probably in the 60v-72v range, maybe 40 mph. So what do you recommend for the engine? Ill post pics of the frame when i finish it.
Old 02-02-2010, 05:45 PM
t0x1k's Avatar
t0x1k t0x1k is offline
Vroom
Whoa buddy....
Unless you weigh like 20 lbs and have carbon fiber skin and bones I wouldn't even think of PVC or any plastics for a go kart. Imagine how PVC breaks. It breaks into dagger like pieces, now imagine one lodge in your rear...Yeah, don't think so.
RIP HoffCo/Comet Industries 10/20/2009
This is a sad day for the karting and mini bike industry
Old 02-02-2010, 05:49 PM
mike75925's Avatar
mike75925 mike75925 is offline
thinker and tinkerer
hope you have done your homework on a plastic frame. electric motors have a lot of torque. the 6.5hp motors will generally get you there. most of speed is gearing and weight. 2 strokes vibrate too much, so i would say 4 stroke. any idea of the karts weight? the frame with all running gear except motor and driver. wrapping pvc in fiberglass doesn't seem as strong as filling the pipe with fiberglass
deo non fortuna
Old 02-02-2010, 05:50 PM
Russ2251's Avatar
Russ2251 Russ2251 is online now
AZUSA LAWN-BOY E
Did a quick search and found this:
http://rob_fed.tripod.com/PDF/pvckart.pdf
Those that can, do. Those that can't, buy a Predator!
Old 02-02-2010, 05:58 PM
Doc Sprocket's Avatar
You, sir, are a braver man than I.
Old 02-02-2010, 06:23 PM
dpaxson's Avatar
dpaxson dpaxson is offline
Quote:
actually wrapping it would be stronger for the same reason that larger thin walled tubing is stronger than smaller thick walled tubing. also filling it with expanding foam might add some strength too
  #7
Old 02-02-2010, 06:30 PM
mike75925's Avatar
wrapping it by crossing the grain of the glass would strengthen. rod flexes, tube not so much. sand the pipe with some 80 grit paper for good adhesion. and wipe down with acetone or something too. are the pipes going to be vacuum bagged?
deo non fortuna
  #8
Old 02-02-2010, 06:31 PM
Junior Member
Update, i found a 120v electric engine in a shopvac, you think i can suscesfully run it at like 72v?
  #9
Old 02-02-2010, 06:33 PM
Junior Member
Quote:
thanks!
  #10
dpaxson's Avatar
it's probably AC so unless you get a big inverter, no
  #11
Old 02-02-2010, 06:34 PM
Junior Member
vacuum bagged? vas is das?
  #12
Old 02-02-2010, 06:35 PM
I have heard that running an AC motor at a substantially lower voltage is detrimental to it's health. No idea if there's any truth to it...
Wait! 72v DC? thru an AC motor? Nope.
  #13
Junior Member
Quote:
ok well what would you recommend for a cheap cheap fast engine? something i could find...mabye even...steal O.o
  #14
Old 02-02-2010, 06:37 PM
Junior Member
ooooo i like, this is similar to what i had in mind, but i looks like if i do this ill have to run out and buy alot my PVC parts !
  #15
Old 02-02-2010, 06:39 PM
Junior Member
ohh and im using 2" PVC parts and tubing, incase anyone needs it for...anything lol
  #16
Old 02-02-2010, 06:41 PM
Is that the white stuff? ABS (the black stuff) I think is thicker.
  #17
Old 02-02-2010, 06:46 PM
Junior Member
its abs, but i really think with fiberglass and mabye some foam in critical areas this thing could really work...and i have no welding experience.
  #18
Old 02-02-2010, 07:30 PM
Junior Member
any other ideas?
  #19
Old 02-02-2010, 08:29 PM
mike75925's Avatar
what schedule? i know of schedule 40, but i only dabble in plumbing. i think the higher the number the thicker.
deo non fortuna
  #20
Old 02-02-2010, 08:40 PM
Junior Member
to be honest is the schedule that is on the shelf at home depot, lol i didn't rly look more then that.
and i think im going to layer smaller pipes inside of the frame, and a small metal pipe on the very inside, like this
http://pvcbuggy.com/plans.html
Closed Thread
