Closed Thread
Old 12-22-2009, 12:16 PM
323i Wagon 323i Wagon is offline
Junior Member
Default Help me identify this frame please.
I picked this up as a little side project and plan on totally rebuilding it. I cant find any markings or numbers so I just wondered if someone could identify it. Thanks for looking.
Old 12-22-2009, 12:55 PM
1992suburban's Avatar
1992suburban 1992suburban is offline
I wanna go FAST!!
margay sprint style maybe
Yeah, I built it for my kids...
Old 12-22-2009, 01:31 PM
anderkart's Avatar
anderkart anderkart is offline
I'm not sure but that chassis has a pretty uniqe lower steering column support design that should help ID-ing it. If you still have the front bumper, slide it back on the mounts and post another pic with it on. Sometimes those front bumpers really help ID-ing.
Does it seem have mostly Metric or American bolts?
Old 12-22-2009, 01:39 PM
I wanna go FAST!!
not a margay the seat supports are wrong. (i think)
man theres no telling really..
Old 12-22-2009, 06:11 PM
Junior Member
In the first pics you will notice dual throttle cable and master cylinder brackets. The lower seat supports have been added to and the seat that was on it was very small. I assume it was set up for a child at some point. That would explain the weird lower seat mounts. I have already removed the extra brackets except for the seat mounts. It also had a flat motor plate welded to it at one point and I have ground off the crappy welds.
See if these pics help any more. I would love to determine what it is or at least approximately how old it is.
Old 12-22-2009, 06:13 PM
Junior Member
I forgot to add that it also had pedal brackets closer to the seat. I have taken these off as well. We already have a racing cart that my father has set up with adjustable pedal brackets for my 8 year old. This cart will be for the "big boys".
  #7
Old 12-22-2009, 09:19 PM
anderkart's Avatar
Man I know I've seen a chassis like yours before but I cant remember what brand.
See if it has any (or all) metric nuts and bolts?
Also try to mesure the rear axle diamitor with a caliper to see if its a 1.25" or a 30mm./35mm. This info might help us narrow down if its a European or American brand.
I'm kinda getting the feeling its an 80's era kart.
  #8
Old 12-23-2009, 06:51 AM
Junior Member
I cant remember anything being metric while taking it apart. Then again, my 8 year old did alot of the disassembly.
I'll measure the axle first chance I get to borrow a set of calipers.
  #9
Old 12-28-2009, 11:46 AM
I wanna go FAST!!
Looks like a millenium similar kart posted on another forum
  #10
Old 12-29-2009, 05:56 AM
Rickracer's Avatar
Rickracer Rickracer is offline
RM250 Race Kart Driver
That looks a LOT like my kart, which my best guess is that mine's a Trick/Olympic.
RM250 Shifter Kart Vid: http://youtu.be/Iz9tcrGx2PU
Youtube channel: www.youtube.com/user/MrRickracer/
  #11
Old 12-06-2012, 04:18 PM
souperman000's Avatar
souperman000 souperman000 is offline
to the forum!
Whay don't you start a new thread (in the apropriate section, button is on the upper left) for yourself? You will get more responses.
no sense in digging out a 3 year old thread.
It's hard to help people that won't help themselves.
The Following User Says Thank You to souperman000 For This Useful Post:
dtsministroker (12-06-2012)
Closed Thread
