moved pics to new folder, links broke. view above post for all the pics so far in this thread.
That doesnt look bad at all, how much compression does it have? Put in a carb kit if you cant get it running, as for the fly wheel, just sand the magnet part down and it should work, i did that for a motor i found in snow bank in the spring.
i dont know about compression yet, looks good but i had my thumb over the exhaust port and heard hissing wen i rotated it. and with my thumb over the spark plug hole. it needs gaskets too. carb looks good at the moment. gonna soak it in parts cleaner/carb cleaner. i need to wash everything too. its dirtyyyy. they diddnt change the oil at all. i bet that was why it diddnt run.
lol if thats why then it may be more expensive to re build the complete bottom end.
hell its a free motor... only replacement parts im getting is gaskets... untill i start to order my performance parts.
im soooo close to cleaning it BUT! i cant get the flywheel off...
#7
well i got the flywheel off! i wasnt hittin it hard enough! lol so its finally down to bare block! store closed so i couldent get any parts washer... i had NOTHING here lol so im going to the store 2marro to get some. and some hemi orange paint! yes thats right, im painting the block and the sheet metal blower/cover either high gloss black or orange too. wat do you guys think?
oh and... MORE PICS ADDED TO THE FIRST POST! Last edited by Jblankster; 10-18-2007 at 08:13 PM. |
#8
is the liner alumineum ???? lol all my hondars are steel and my bikes crome lol dont thay last long ?
there's no replacement for displacement |
#9
looks good, exhaust sould work fine. go with the orange if its a unique color of orange, theres orange engines out there but all the same orange. maybe make the cover black?
#10
i was talking to m y metro friend (he isnt gay, he is metro!), who does paint and body work on cars and he was thinking like a HEMI orange, and a flat black engine cover. what do you think?
im kinda lazy to go to the store, can i jus wash everything with simple green and water? Last edited by Jblankster; 10-18-2007 at 08:14 PM. |
#11
i dont know what simple green is but water and metal dont mix, especcaly in motor, the paint you described would look absoutly aoesome.
#12
well i used 1 can of gunk, 1 can of brake cleaner, 1 bottle of simple green and some good ol elbow grease and it turned out nice!
http://i67.photobucket.com/albums/h3...1/IMG_3296.jpg http://i67.photobucket.com/albums/h3...1/IMG_3295.jpg http://i67.photobucket.com/albums/h3...1/IMG_3297.jpg http://i67.photobucket.com/albums/h3...1/IMG_3300.jpg http://i67.photobucket.com/albums/h3...1/IMG_3294.jpg http://i67.photobucket.com/albums/h3...1/IMG_3293.jpg http://i67.photobucket.com/albums/h3...1/IMG_3291.jpg http://i67.photobucket.com/albums/h3...1/IMG_3290.jpg http://i67.photobucket.com/albums/h3...1/IMG_3289.jpg http://i67.photobucket.com/albums/h3...1/IMG_3288.jpg http://i67.photobucket.com/albums/h3...1/IMG_3287.jpg http://i67.photobucket.com/albums/h3...1/IMG_3286.jpg http://i67.photobucket.com/albums/h3...1/IMG_3285.jpg i did use water, but i put some oil around any metal to metal internals that might rust so im all good. oh and i decided on the orange with flat black |
#13
im painting it 2marro, just masked off everythin i needed to. i cant wait to run this thing!
#14
painting done, once dry will post pics.
#15
Cool cant wait to see this, what mods are you going to do?
#16
#17
![]() ![]() ![]() ![]() ![]() it turned out perfect, although its not done you get the idea of how its gonna look. all i need is a gasket set for it and it'll be complete. oh and i forgot what the timing mark on it is! so i need to figer that out, i thought i did 1 time but the counterweight would hit the cam lobes, then i thought i did again but the end of the rod hit the camshaft. i need to get it right. oh and does anyone know the torque specs for these parts? (rod head, any bolts on it )
#18
i never use torque specs, i tighten as hard as i can without stripping, are you going to put a bigger cam in while its all apart? you sould reseat the valves while its apart too, itll give you much more compression, that way when and if you need to rebuild it you know its the rigs or the piston.
#19
right now im just gonna try to get it started, if it runs then im gonna get stuff for it.
im having a rod bearing problem, i think its on backwards. need to figer it out. ordering gaskets and k&n air filter kit for it now. what ya think about the paint? |
#20
absolutly killer
| Thread Tools | |
| Display Modes | |
