Go Back   DIY Go Kart Forum > Building Plans And Advice > Using Tools and Welding
Reply
Old 10-12-2009, 07:14 PM
02mx-5 02mx-5 is offline
Default Arc welding with a battery charger?
Is it possible to arc weld using a large battery charger? I hooked it up to my pocketbike to start it and touched some metal togeth by accident. it looked as though i was welding as i saw the arc. If i were to put a rod in the positive clamp could i weld if i set it to 12v high?
Old 10-12-2009, 07:22 PM
lemegacool's Avatar
lemegacool lemegacool is offline
got boost? :)
no wont work... welding rods needs like 50-80 ocv (open circuit voltage) to operate... 12v wont light them
Old 10-12-2009, 07:28 PM
Kaptain Krunch's Avatar
Kaptain Krunch Kaptain Krunch is offline
Pro Junk Collector
you can weld with 3 car batteries wired in a series.
"If you want, I can teach you how to make a bomb out of a toilet paper roll and a stick of dynamite"
Old 10-12-2009, 08:01 PM
Kenny_McCormic Kenny_McCormic is offline
Kartless....
You can ghetto rig a stick welder w/2-3 few car batteries and some jumper cables. Certain truck alternators make great TIG welders.
Old 10-12-2009, 08:54 PM
oscaryu1's Avatar
oscaryu1 oscaryu1 is offline
Pie es bueno
12V charger can't keep up with the amerage flow, and won't start the arc at all.
With my pile o' batteries, 200-300V is achievable far too easily lol.
Although charging them back up will be a PITA.
ohaithar
Old 10-13-2009, 10:27 AM
Ok, i had to ask.
  #7
Old 10-13-2009, 10:33 AM
ApocGoD ApocGoD is offline
Deus Ex Machina
Quote:
I can see this ending badly.. Very badly..
ApocGoD
My normal feelings:
  #8
Old 10-13-2009, 01:01 PM
Kartless....
How so?
  #9
Old 10-13-2009, 01:39 PM
frederic frederic is offline
The Junk Man
You can stick weld thin stuff (with a thin rod) with a single car battery. It's difficult to strike the arc and maintain a welding puddle however. 24V (two batteries) or 36V (three batteries) is the range I'd recommend playing with if you want to weld with car batteries. I've done it many times and it works reasonably well.
Car and truck alternators work well also and you can use an old interior/dash light dimmer in series with the field coil to control current somewhat. Obviously not all welding jobs demand full power and thinner stuff can blow through.
A car charger can provide it's start rating only for a few seconds, typically 15-20 max. These things are designed to suppliment a weak battery and not replace it entirely. This is why if the battery is completely dead you cannot start it with a charger/starter - the battery isn't helping at all and probably sucking more current than the stater, at least initially.
Just be very careful. Amps can kill you very easily.
  #10
Old 10-14-2009, 12:32 PM
Raywelder's Avatar
Raywelder Raywelder is offline
Not an Adm¡nistrator
Youtube it!
I did last night and theres a really good video demonstrating how to do it, I was impressed on how good it welded, considered they are car batteries.
  #11
Old 10-14-2009, 02:58 PM
freakboy's Avatar
freakboy freakboy is offline
the names 'mater
U could probaly hook a tractor generator or two up to a pully system and engine and make some sort of circut to make the flow variable and then you use jumper cables and walla.
Pardon me, sir gangster! but it apears your pants are declining in elevation!
  #12
Old 10-15-2009, 11:14 AM
r_chez_08's Avatar
r_chez_08 r_chez_08 is online now
Should be in the shop...
i touched the two terminals together on a small 12v battery charger, and it seemed to create a small arc.
My process of thought:
Anyone can drive a fast car, few can drive a car fast.
  #13
Old 10-15-2009, 05:22 PM
oscaryu1's Avatar
Pie es bueno
Quote:
Even if it didn't arc and just stuck and shorted, the batteries are powerful enough (SLA car batteries have major amerage), it would just burn and glow the stick/wire up until it fried.
No harm done, happens if you're bored with a wirefeed ARC too.
ohaithar
  #14
Old 10-15-2009, 06:19 PM
Kartless....
According to my old man, back in the day before he had a real load tester he would short batteries with a piece of coat hanger wire. If it burned the wire in half, it was a good battery.
Reply
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
