Go Back   DIY Go Kart Forum > Other Stuff > Off Topic Fun
Reply
Old 10-07-2009, 04:38 PM
freakboy's Avatar
freakboy freakboy is offline
the names 'mater
Default tachometer
yall think this would work?
http://www.harborfreight.com/cpi/cta...emnumber=98480
Pardon me, sir gangster! but it apears your pants are declining in elevation!
Old 10-07-2009, 04:43 PM
lemegacool's Avatar
lemegacool lemegacool is online now
stupid vehicle maker
Quote:
Originally Posted by freakboy View Post
"Works with 4, 6 or 8 cylinders"
so on a single cyl... no
Old 10-07-2009, 04:56 PM
kazkepox's Avatar
kazkepox kazkepox is offline
Pro- one idea to the next
dang i was about to jump on it too lol
Old 10-07-2009, 05:08 PM
kazkepox's Avatar
look around on here
http://www.ecvv.com/product_directory/Speedometer.html
Old 10-07-2009, 05:22 PM
freakboy's Avatar
the names 'mater
well i got a 2 cyl! so u think it would work on that? i saw some guy on youtube with one of them on one of his lawn mowers.
Old 10-07-2009, 05:32 PM
Kaptain Krunch's Avatar
Kaptain Krunch Kaptain Krunch is online now
Pro Junk Collector
It wouldnt read correctly on only 2 cylinders. If you get a cable driven tach, you can mess with the gear ratio until it reads correctly, i think thats your best bet.
"If you want, I can teach you how to make a bomb out of a toilet paper roll and a stick of dynamite"
  #7
Old 10-07-2009, 05:41 PM
freakboy's Avatar
the names 'mater
alright =( i might try it its only 20 bucks and if it dont work right ill mess with my freinds and just keep it on there and have it hooked up so it does move. and i dont care if its spot on i just want a tach lol i already got a temp gauge for the lower cyl that gets really hot.
  #8
Old 10-07-2009, 06:44 PM
lemegacool's Avatar
if you want a tach that bad look on ebay for numeric tach/hourmeter they are like 40$ and designed for 1 cyl engines
EDIT: found this : http://cgi.ebay.ca/Tach-Hour-Meter-m...d=p3286.c0.m14
that would work!!! but i'd ask the seller first! to be sure...
  #9
Old 10-07-2009, 08:00 PM
jetlag jetlag is offline
That one looks similar to the "Tiny-tach."
http://www.tinytach.com/tinytach/gasoline.php
I'd like to know how fast it updates, but probably slow like that the cheapo Tiny Tach @ ~2.5s
  #10
Old 10-07-2009, 08:01 PM
Raywelder's Avatar
Raywelder Raywelder is online now
Not an Adm¡nistrator
The only ones that i have seen that will work are digital, and I rather not have digital.
I was reading that some of the ones designed to work on the 4cyl might work on 2cyl due to 4cyl using a waste spark system? something along those lines. You'd have to research that.
  #11
Old 10-07-2009, 08:30 PM
t0x1k's Avatar
t0x1k t0x1k is online now
Vroom
I read the instructions in the store and the one line is tapped into the wire that goes to the dist or coil pack, I imagine you could just tap into the spark plug?
I was going to get it and fool with it and just put it on my truck if it doesn't work, but $20 is a bit too much for that tiny gauge. Probably find a big one on craigslist for the same price.
Reply
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
