Go Back   DIY Go Kart Forum > Announcements & Suggestions > Introduce Yourself!
Reply
Old 07-08-2009, 09:43 PM
GoDaddy's Avatar
GoDaddy GoDaddy is offline
Beginner Member
Default Help! Naming parts
I just got a good deal on a used Razor Electric Go Kart for my son only $20. Yes, $20 retail at $229. The throttle wasn't working but when I check once we got home, the kill switch wire was shorted out. Problem solved.
Problem not solved. My nephew wants one just like that and his dad couldn't afford a $229 gokart. I thought I would try to build him one using motor from razor E100 scooter that I got along with the gokart, for free. Just need a battery and swap the controller because the E100 is a kick start.
Anyway, before I can begin, i need to know names and terms.
On the back axle/wheels, what do you call that part where the frame and the axle meets? The part that make sure the axle/tires doesn't roll left and right. Same time I guess support the frame.
Hope, i worded that correctly.
Old 07-10-2009, 06:07 PM
GoDaddy's Avatar
Beginner Member
hmmmm 2 days and now reply. Maybe I'm missing intro.
Introduction:
My name is Dan and I'm an alcoholic, j/k.
I have no knowledge in go kart(newbie).
Tho I have much knowledge with pc.
I am quick learner that's why i'm determind to build a gokart and will sure share the picture when complete.
Old 07-10-2009, 06:35 PM
Rotore Rotore is offline
Teh SPIK
your thinking of bearings and a lock collar
"No one is going to open doors for you your whole life, sometimes you have to open the dor yourself." Eddy
Old 07-10-2009, 11:37 PM
EagleTalons's Avatar
EagleTalons EagleTalons is offline
Master JB Welder
Welcome to the site GoDaddy!
Old 07-13-2009, 03:03 PM
GoDaddy's Avatar
Beginner Member
Thank you Rotor-E. Now I can look/search for parts.
Quote:
Old 07-13-2009, 03:25 PM
Teh SPIK
they're fairly easy to find
  #7
Old 07-15-2009, 08:47 PM
GoDaddy's Avatar
Beginner Member
Default Axle and Wheels
Ok, I do not want to jacked other's(r12) thread. I just found out what I need. I actually need the Pillow Block.
Next question. I dont know how the axle and the wheels works by looking at the tire itself. Is there a part I have to buy to hold the wheels to axle. Once again this is the for the rear. The front i'm not worry because it spin free wheel.
  #8
Old 07-16-2009, 09:46 AM
Teh SPIK
ok you know how a car has a hub the holds the brake disc or drum in place... same on a go kart you need hubs for go karts.
and pillow blocks are basically bearings better for off road use..
  #9
Old 07-16-2009, 04:35 PM
GoDaddy's Avatar
Beginner Member
Are you saying that the pillow block use only for bearing, and doesn't really prevent the axle from sliding?
  #10
Old 07-16-2009, 05:27 PM
GoDaddy's Avatar
Beginner Member
Tho I understand I wish there's someone who might have picture of the wheels and hup before and after installed.
Reply
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
