Reply
Old 11-12-2019, 07:44 PM
Rhill Rhill is offline
Junior Member
Default Engine selection help
Ok guys so I have a buggy that I acquired in a trade. It currently has a gx390 on it. But the buggy is pretty heavy prolly 800lbs or so give or take. Does anyone know of a motor thatís stronger or makes more power than the gx390. It rolls it pretty good on flat ground but not so good on up hill and stuff. Any tips or advice would be great.
Old 11-12-2019, 07:47 PM
950speed's Avatar
950speed 950speed is offline
Well let’s see some pictures of what you have going on:
-transmission
-whole buggy
- gears
It could be that it has the wrong gearing. So let’s see what you have got and we can go from there. Starting the process of elimination which could turn out that you in fact do not need a new engine and you could save a lot of $$
The Following 2 Users Say Thank You to 950speed For This Useful Post:
Kartorbust (11-12-2019), Rhill (11-12-2019)
Old 11-12-2019, 08:17 PM
Junior Member
Ok I’ll have to take some pics of it in the morning when I get to the shop. I can get pics of the buggy and gears but I’m not sure about the transmission not to sound dumb but I didn’t know it had one
Old 11-12-2019, 08:18 PM
Kartorbust's Avatar
Kartorbust Kartorbust is offline
As already mentioned what will help us determine a solution to your problem:
1. What is getting power to the wheels? CVT (what kind)?
2. What kind of gearing is on there now?
3. Tire size?
You probably want close to 8 or 9:1 gearing to move that much weight around.
Pictures of the machine and drivetrain will be helpful. Most engine swaps that will help out will require modifications to the frame and may not be cheap.
Old 11-12-2019, 08:19 PM
950speed's Avatar
It’s probably either a clutch or a torque converter, it’s wha connected between the engine and the axle
The chain connects the trans to the axle.
Transmissions don’t have to be a thing that shifts gears. It can be one single gear, it’s all used to transfer rotational energy in our case
Old 11-12-2019, 08:45 PM
Wilson_Engine_Shop's Avatar
Wilson_Engine_Shop Wilson_Engine_Shop is offline
Supporter
Have you thought about a predator 670cc? It makes more power and torque than the 390cc but you'll need a 40 series TAV to not burn up belts
  #7
Old 11-12-2019, 09:00 PM
Kartorbust's Avatar
With the 670, its huge in comparison to a GX390 and will require extensive modifications. Plus a 40 series may only hold up for a bit. A larger CVT will be better suited, but all that comes at a cost, about $1500 for engine and suitable CVT.
  #8
Old 11-12-2019, 09:59 PM
itsid's Avatar
itsid itsid is offline
800 lbs?
What's it made off?? lead pipe?
J.S.@SMS (11-13-2019)
  #9
Old 11-12-2019, 10:30 PM
Randy H Randy H is offline
How about this bad boy?
38ft-lbs of Torque @ 2200rpm!
Shipping Weight = 89lbs
$899
https://vegascarts.com/collections/e...lf-cart-engine
  #10
Old 11-12-2019, 10:41 PM
itsid's Avatar
625cc single cylinder?
oomph I say.. OOMPH!
  #11
Old 11-12-2019, 10:58 PM
That and a good clutch setup it would pull my Civic around, heck it might pull my F-350. But I'd miss the turbo spoolin' up, lol.
  #12
Old 11-13-2019, 04:31 AM
Budget GoKart's Avatar
Budget GoKart Budget GoKart is offline
Aka a kenbar
Oof that's a big single cylinder
I gotta fix my flathead collection
  #13
Old 11-13-2019, 05:45 AM
Kartorbust's Avatar
Thumpers are great for the power. When you half to pull down a house with a golf cart, you get a thumper.
  #14
Old 11-13-2019, 05:51 AM
Aka a kenbar
Quote:
Do briggs 8hp i/c's count as thumpers or? But dang over 600cc ohv single cylinder what do you put that on, a Chevy c10? Lol?
  #15
Old 11-13-2019, 06:23 AM
J.S.@SMS's Avatar
J.S.@SMS J.S.@SMS is offline
Road Hazard
Nah, I'd use the one cylinder on my drifter (200 pound kart with 23hp, what could go wrong?), and a blown 454 with just a bit on NOS in the c10. Wet system not dry of course.
And we could use some pictures of the drive setup and some sprocket tooth counts.
For his personal safety, keep this one away from bicycles.
  #16
Old 11-13-2019, 06:36 AM
Kartorbust's Avatar
Quote:
I have no idea on displacement cut off for a thumper or not. I think it's generally just a nickname for single cylinder engines.
  #17
Old 11-13-2019, 09:21 AM
JTSpeedDemon's Avatar
2019 Build Off Winner!
with these guys.
That GX390 will move that buggy just fine, it all depends on gearing.
A 625cc single cylinder!!! Can you imagine the ridiculously loud exhaust and the vibrations!!!
But man, that thing would MOVE!!
Currently Flathead-Crazed
  #18
Old 11-13-2019, 11:49 AM
Junior Member
Quote:
Originally Posted by 950speed View Post
Well letís see some pictures of what you have going on:
-transmission
-whole buggy
- gears
It could be that it has the wrong gearing. So letís see what you have got and we can go from there. Starting the process of elimination which could turn out that you in fact do not need a new engine and you could save a lot of $$
Ok so it has a torque converter and the sprockets the small one has 8 points the back has 62 and it has 12 inch tires
  #19
Old 11-13-2019, 11:59 AM
mckutzy mckutzy is offline
Nice... a new contender for the big block crowd...Odd.. doesnt say shaft size....
Looks like they use the head off of a 670 onto a modified big block....
Cool.... heavy though... needs a gastank..
  #20
Old 11-13-2019, 12:20 PM
950speed's Avatar
PICTURES!!
Let’s see it all
Including the torque converter. You said you would now where are they?
Reply
