Reply
Old 06-14-2009, 04:37 PM
greasemonkey85 greasemonkey85 is offline
Default shocks, what to use?
what are some of you guys using for shocks? i ve been looking around and they have mechanical, hydraulic..... etc. i think that most of the go kart shocks i have been looking at will be ok, but i am worried about them being to stiff. i figure the kart will weigh arounf 500 lbs. i know if i keep the shock mount towards the front of the swing arm the travel will be more towards the back than where the shock is mounted, but is 2 or 3 inches of travel still enough?
Old 06-14-2009, 06:30 PM
theo theo is online now
get quad shocks off ebay. If they are to still mount them closer to the hinge on the swing arm.
Old 06-14-2009, 06:34 PM
Kaptain Krunch's Avatar
Kaptain Krunch Kaptain Krunch is online now
Pro Junk Collector
Or sled shocks, i got a few pairs, they have a good amount of travel.
"If you want, I can teach you how to make a bomb out of a toilet paper roll and a stick of dynamite"
Old 06-14-2009, 06:47 PM
well i went to tractor supply tonight and looked at there go karts. they have the same shocks i was looking at and they only had 3" of travel in the shock. but they way they were positioned (close to the pivot point) it had like 6 inches of travel were the axle was. so that is what i am going to get....
http://cgi.ebay.com/ebaymotors/NEW-A...5%7C240%3A1318
Old 06-14-2009, 07:11 PM
Raywelder's Avatar
Raywelder Raywelder is online now
Not an Adm¡nistrator
Those are cheap! And TSC has those?
our TSC musnt have them
Old 06-14-2009, 07:42 PM
mattlepperd mattlepperd is offline
Those shocks are VERY soft. 100 LBS will compress both of them
  #7
Old 06-14-2009, 07:56 PM
If it takes 100 lbs to compress them 1" then they are ok.
theo
  #8
Old 06-14-2009, 08:44 PM
newrider3's Avatar
newrider3 newrider3 is online now
"wtf is this"
If they are too soft even with proper positioning, you can always double up.
  #9
Old 06-14-2009, 08:53 PM
Here is a better deal.
ebay 290323047911
theo
  #10
Old 06-14-2009, 09:32 PM
no tsc didnt have shocks, i was looking at the go karts they had for sale.
where did you guys see 100lbs on that listing. i didn t see anything. that is what scares me...
  #11
Old 06-14-2009, 09:34 PM
i dont really want to get a used set, i d rather buy new. i tried buying used stuff and the wifey complained about making the kart crappy. i might just get the pair from northern that they have, i don t know. they are only 2 inches of travel but i know that is what they are meant for.... allthough 520 lbs seems like alot. maybe like stated above, i ll make a mount with several mounting holes for the top and bottom so i can move forward or back on the swing arm.
  #12
Old 06-14-2009, 09:42 PM
Umm..no..it takes 100 lbs to SMASH THEM. If you want a pair send me 10 bucks to ship them and I will retrieve them from my scrap bin.
  #13
Old 06-14-2009, 09:43 PM
They list no specs..I have a set and they are POOP.
  #14
Old 06-14-2009, 09:45 PM
What exaqctly are you building? Do you have pictures here? I am also building a heavyweight. I am putting Articat shocks on the rear.
  #15
Old 06-15-2009, 12:09 AM
88s10Durango 88s10Durango is offline
I`m buying motorcycle shocks for my off road kart , you could use a single mono shock say from a 250 or so dirtbike on the back , I`m going a weird route on my rear setup , I`m going to use a set of front forks off a dirtbike and remove the inner spring and convert them to air , their 35"s long so I`ll make the top mount up on the roll cage and lower on the A-arms kinda like the way this Piranha is setup ,, Bill
  #16
Old 06-15-2009, 01:28 AM
modelengineer modelengineer is online now
Building Sidewinder Buggy
Just to give you an idea, the Piranha uses 200lb springs on the back, and 600lb springs on the front.
Andrew
Sidewinder mini-buggy in progress
  #17
Old 06-15-2009, 07:17 PM
what about these? http://cgi.ebay.com/Manco-Go-Kart-17...3A1%7C294%3A50
  #18
Old 06-16-2009, 05:13 PM
Pro Junk Collector
I would just go for a pair of front end sled shocks. The shocks i got off a polaris storm take a hell of a lot of effort to compress, have a decent amount of travel and are 5 position adjustable.
  #19
Old 06-18-2009, 08:39 PM
Default still need some help!
http://host179.ebm.bestsoftwarehost....TI_ITEM_SUBMIT
what do you guys think about these shocks? maybe to stiff?
i m still not understand the difference between a mechanical shock and a hydraulic shock. i think these might be pretty good?
  #20
Old 06-20-2009, 10:55 PM
lyndong4 lyndong4 is offline
Junior Member
mechanical is just spring force, hydraulic have oil in them, so theyre the stiff ones
Reply
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
