These are the pictures Oscar was talking about the lawnmower flywheel explosions. Now just imagine if that hit somone....Look what it did to a Iron supporting beam in his shop!
http://gardentractorpullingtips.com/...e/flybreak.htm
Go kart is finished! |
He probaly had a steel key on flywheel so he hit something and without the govenor or a broken one it split appart.
Pardon me, sir gangster! but it apears your pants are declining in elevation! |
This is tractor pulling here. Some of you guys here asked for documentation of a flywheel killing/severely injuring people. I got those pictues of 4 cycle and theres alot of people over there who agree and have seen flywheels explode on a STOCK engine with just the governer removed.
If you had read the page, you would've noticed it wasn't a lawn mower in use, it was an ungoverned engine on a racing mower.
i have seen a few threads about this, but for the most part it was user error, like one guy lightening a stock flywheel.
"If you want, I can teach you how to make a bomb out of a toilet paper roll and a stick of dynamite" |
Ohhh well reading isnt my kinda thing do to and i just got back from a party..........so yeah.
#7
Quote:
"In a cosmic setting vast and old beyond ordinary human understanding we are a little lonely..." |
#8
Wow, Went through the wall even! and dented that beam. Thats amazing.
#9
Im not sure if this would also be a problem but the flywheel itself is one with built in blades would the drag on that make enough force to make it less stable or something like that then do this?
#10
I would like to see documents of a flywheel exploding on a new engine. You don't know the history of a old fly wheel, it could of been removed with a sludge hammer once.
theo |
#11
I recently posed this question on another forum and here's the answers I got.
Post #1 Quote:
Quote:
#12
What i would like to do (and might when we move into a new house) is start collecting free push mowers that people dont want, get them going good then take a day, set them up in a field with a string on the governor, and one by run run them till they blow and see just how many flywheels actually fly apart. I would have to carefully torque and inspect each flywheel, but even with an old wheel i dont think any of them will explode before the engine throws a rod or something like that.
| The Following User Says Thank You to Kaptain Krunch For This Useful Post: | ||
Affair_driven (06-06-2009) | ||
#13
Quote:
Nobody has yet to prove otherwise.
#14
I have a old Briggs 3 HP with removed governer and It will only rev to 3900-4000 RPM before the flow cannot keep up and I've never had a flywheel probelem. I'm making a new cam for this engine ATM
If you take a stock Briggs cast iron flywheel and turn it up to 10,000 rpm, which many limiteds will do, the magnet is moving at 256 ft per second. And, do to inertia weight and centrifugal force, that magnet weighs in at 2808 pounds. Being hit by just the magnet is like standing out in the middle of the freeway and letting a small car hit you at 60mph. How many guys are up for trying that on ? Don't be a dork. Use a billet flywheel. If you can't afford one, don't race till you can afford one. It's not just your life that is at stake.
#15
Quote:
#16
Jr, dont get me wrong, i do believe a flywheel will explode if you can get it to spin constantly at 10k for a little while, but without lots of modifications you will not get it to 10k, and if your putting that kind of money to completely redo the engine, then you most likely will and can get a billet flywheel. What i was talking about was JUST removing the governor and nothing else, and doing that you would be lucky to get past 5k and at 5k with all stock engine you will most likely throw a rod or blow something else before the flywheel explodes.
#17
I agree if you are racing, but most guys here i believe are only using their engines in a yard or off road kart. I think, but could be wrong, but is it sustained high rpms that makes a flywheel come apart?
theo |
#18
Lol. I suppose you guys are right, Briggs, Tecumseh, Kohler ETC all designed these engines incase of mechanical governer failure and worst case situation.
| The Following User Says Thank You to jr dragster Tyler For This Useful Post: | ||
#19
Quote:
But I did recieve an email from a good friend of mine saying at the track, when 5HP flywheels started to come apart, they switched to 3HP flywheels (less rotating mass - less chance of KABOOM), and it stopped most of the explozions. If anything, at least switch to a CAST 3HP flywheel.
ohaithar |
#20
So is the Aluminum flywheel on my 3 HP a hazard when I get my new cam in there?
| Thread Tools | |
| Display Modes | |
