Reply
Old 05-15-2009, 10:29 AM
timbecht timbecht is offline
Junior Member
Default 5 horse 2 stroke vertical shaft ?????
i have a very good lawnboy 5 hp 2 stoke motor besides remounting the carb what else do i need to do to run it horizontal shaft for my kart project
if you run a set up like this please post some pics for me also thanks in advance
or any info on doing this set up would be great and thanks again
Old 05-15-2009, 10:37 AM
JerryAssburger's Avatar
JerryAssburger JerryAssburger is offline
Admiral Annoy
Russ has threads on this (check the search option) and it mostly involves rotating the carb to the right orientation, making a mount, finding a clutch or drive that'll fit the output shaft. I have a Briggs 2-stroke, and so far, rotating the carb was the easy part.
When it gets scary, it's almost Fast Enough!
Old 05-15-2009, 12:43 PM
Junior Member
i did a search and didnt find much could u point me in the right direction
Old 05-15-2009, 03:02 PM
anderkart's Avatar
anderkart anderkart is offline
Here's a link to all of Russ 2251's posts:http://www.diygokarts.com/vb/search.php?searchid=62956
I only read through a few, but you'll find he's posted a lot of great info about installing Lawn-boy motors on karts.
Old 05-15-2009, 09:12 PM
Junior Member
link is not working
  #7
Old 05-31-2009, 10:47 PM
Junior Member
here they are russ
Reply
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
