Go Back   DIY Go Kart Forum > Building Plans And Advice > Electric Projects
Closed Thread
  #21
Old 08-28-2017, 10:01 AM
Functional Artist's Avatar
Functional Artist Functional Artist is offline
Double check ALL connections
...for correctness
...& tightness
Loose lips may sink ships
but, loose connections get hot & melt stuff
Lets give 'er a try
  #22
Old 08-28-2017, 10:24 AM
I wasn't happy with the return action of the pedal actuated thumb throttle
Will tinker with it & adjust later
Here is another idea
Just mount the thumb throttle on the steering wheel
...with a piece of pipe & a small U-bolt
  #23
Old 08-28-2017, 11:20 AM
ezcome-ezgo's Avatar
I thought that throttle set-up looked a little sketchy. But you are rockin' it now!
The Following User Says Thank You to ezcome-ezgo For This Useful Post:
Functional Artist (08-28-2017)
  #24
Old 08-28-2017, 12:20 PM
Time for some testin'
But, wait
If were gonna gather some data
We gotta get our meter hooked up
So,
I mounted the shunt onto a plastic base
...strapped it to the bat trees
...hooked the side labeled "battery" of the shunt to the negative (-) terminal of the bat tree pak
...hooked the negative battery cable (formerly went to bat pak negative) to the side of the shunt labeled "motor"
...hooked the meter lead wire to the positive (+) wire going into the motor
Yup!
Now were ready
  #25
Old 08-28-2017, 08:18 PM
First test run
Kart: e-Lemon-aid
Motor: 24V 450W DC brushed motor (Turbo stressed)
avg amp draw: 15A
max amp draw: 31A
max speed: 11 mph
Run time: ~40 min.
The Following User Says Thank You to Functional Artist For This Useful Post:
ezcome-ezgo (08-29-2017)
  #26
Old 08-29-2017, 03:06 PM
Mounted up another
24V 450W (non stressed) motor
on e-Lemon-aid
The data was pretty much the same
but, the top speed was lower (~9 mph instead of ~11 mph like before)
I was expecting better performance
NOT worse ???
avg. amp draw: 15A
max amp draw: 30A
max speed: 9 mph
run time: ~40 min.
  #27
Old 09-01-2017, 09:53 PM
Next,
Were gonna step it up a bit
Were gonna jump up to a MY1020 48V 1,000W brushed DC motor
It's rated current is 26.7 amps & it is speed rated at 3,000 rpm's
I had to do some adjusting, the sprocket was off about 1/4"
ezcome-ezgo (09-05-2017)
  #28
Old 09-03-2017, 11:41 AM
Test run was fun
This 48V 1,000W motor is very perky/torquey.
It zips to 10 mph like quick
It moves right along & seems to transverse grass as well as it does pavement.
With this set up it speed tops out at just under 15 mph
The meter showed that it drew ~25A at take off and averaged ~8A most of the ride.
alim (09-03-2017)
  #29
Old 09-03-2017, 07:18 PM
alim alim is offline
Did the kart come with that axle sprocket?
  #30
Old 09-03-2017, 11:01 PM
Quote:
Yup, looks like the factory sprocket that's been on there for years
It has an 84 tooth axle sprocket & a 10 tooth motor sprocket for an 8.4:1 ratio
Very torquey (if that's even a word)
---------- Post added at 11:01 PM ---------- Previous post was at 10:36 PM ----------
Well, someone seems to be impressed with what we are doing
This message was left on the 48V 1,000W test drive video
Awsome!. This is Mike from Alfa Wheels. Please visit my ebay store and mention this video, I will give you a 10% discount for any item not already discounted. http://stores.ebay.com/alfawheels1.
Clean, powerful & discounts
  #31
Old 09-04-2017, 06:10 AM
I've seen their ads on eBay, they have really great prices on motors. Based out of Florida.
The Following User Says Thank You to alim For This Useful Post:
Functional Artist (09-04-2017)
  #32
Old 09-04-2017, 06:38 PM
Did some more testin' today
So far, 48V is the way to go!
It scoots right along on pavement & off road
...& it even does burn outs
Way more powerful & draws less from the bat trees
Double bonus
  #33
Old 09-04-2017, 06:53 PM
Lol I think I know my way around your neighbourhood almost as well as you do
The Following 2 Users Say Thank You to alim For This Useful Post:
6.5hp (12-28-2017), Functional Artist (09-13-2017)
  #34
Old 09-04-2017, 08:43 PM
Talking about the Boma 48V 1,800W brushless motor earlier made me think,
I haven't got El Dingo II out lately
I want to mount the Boma motor on e-Lemon-aid to get some data
But, I wanna have some fun first
So, lets get 'er out-n-play today
  #35
Old 09-13-2017, 09:33 AM
I mounted the Boma 48V 1,800W brushless motor & controller on e-Lemon-aid.
I made a terminal cover/pouch to help make a safer kart
It will cover up the open terminals on the motor terminal connection port & I can tuck the other plugs in there also to help protect our other connections too.
The data seemed to be close to the 48V 1,000W brushed motor
avg amp draw: 8A
max amp draw: 29A
top speed ~15 mph
  #36
Old 09-13-2017, 10:12 PM
Hold the presses!
"This just in" New information
A message has been left on one of the e-Lemon-aid videos that says:
"The diagram leaves out the "stalls" wiring which is important as it sets the RPM of the motor. If its not connected it runs at middle speed and not at its full RPM."
So, after doing more research, it seems that the "stalls" plug is for a (3) speed switch
If you connect the black & blue wires you get low speed ~2,680 rpm's
If nothing is hooked (like I have it now) it runs at med speed ~3,450 rpm's
& if you connect the black & green wires the motor runs at it's highest speed ~4,150
Yup!
Ima doin' some testin' tomorrow
Stay tuned
The Following 2 Users Say Thank You to Functional Artist For This Useful Post:
Bmr4Karts (05-14-2019), constructionpro123 (06-18-2018)
  #37
Old 09-14-2017, 10:11 PM
Well, we have another translation
..."stalls" means (3) speed switch
So, if you want to have full speed always available
...just connect the green & the black wires
But, to make this feature fully functional
...you will need an on/off/on switch
The Following 4 Users Say Thank You to Functional Artist For This Useful Post:
alim (09-15-2017), Bmr4Karts (05-14-2019), JagLite (11-27-2019), Malcost (11-19-2017)
  #38
Old 10-12-2017, 03:58 PM
MadManAndrew MadManAndrew is offline
Fun-Club Chairman
Here’s a cable pull throttle specifically for conversions like this. https://electricscooterparts.com/thr...blepullhrottle
2017 DIYGK Build-Off thread http://www.diygokarts.com/vb/showthread.php?t=35721
The Following 3 Users Say Thank You to MadManAndrew For This Useful Post:
Bmr4Karts (05-14-2019), Functional Artist (10-12-2017), sikbrik (11-11-2018)
  #39
Old 10-13-2017, 08:59 AM
Quote:
Yup, that's a great solution
It makes it easy to hook up to the stock (gas) pedal & provide throttle signal input to your electric motor controller.
It eliminated the need for goofy looking (add on) pedals &/or twist & thumb throttles.
  #40
Old 12-26-2017, 10:01 PM
garolittle's Avatar
garolittle garolittle is offline
Great videos. I watched the first 11 today and will finish the rest tomorrow. Thanks for postingbthese.
The Following 2 Users Say Thank You to garolittle For This Useful Post:
Bmr4Karts (05-14-2019), Functional Artist (12-27-2017)
Closed Thread
