Go Back   DIY Go Kart Forum > Build Contest > Did not Finish Logs
Closed Thread
Old 02-05-2017, 09:44 AM
2SlickNick's Avatar
2SlickNick 2SlickNick is offline
American Minibikes @ FB
Default 2017 - Sidecar - DNF
Okay 2017 is here... I have been a part of this great place for sometime now, I have had some good builds in that time too, and have decided it is about time to enter the build off.
I have decided to join DIYGK's two main vehicles of daily disccussions - together.
I have decided to make a big tire minibike with a two seater gokart-sidecar.
I will use a 212 Predator and torque converter for a power plant, I will make safer, and better big tire sidecar. The sidecar is going to be a leaner style like my first sidecar build.
This is going to be cool, so hold onto your keyboards and enjoy the ride!
https://www.youtube.com/user/dirtyinaz
Old 02-05-2017, 03:08 PM
ultralight01's Avatar
ultralight01 ultralight01 is offline
Senior Yet Young Member
Nice! This will be cool. And your avatar wants to give me nightmares.
I like go karts and I like motorbikes.
The Following User Says Thank You to ultralight01 For This Useful Post:
2SlickNick (02-05-2017)
Old 02-05-2017, 05:18 PM
2SlickNick's Avatar
All unnecessary parts removed off of the go kart.
Old 02-05-2017, 05:21 PM
2SlickNick's Avatar
One seat in front and one seat in back. Rear seat will be slightly higher than the seat in front.
I am also considering making a seat and sissy bar for a rider behind the driver. Four people on one bike, yeah this will be awesome.
Old 02-05-2017, 05:50 PM
Bbqjoe Bbqjoe is offline
Banned
You think a 212 will move four people?
1 adult and 3 toddlers maybe.
Old 02-05-2017, 06:35 PM
2SlickNick's Avatar
I know it will... torque converter and geared low. I could always use my 7" driven if needed too.
---------- Post added at 06:35 PM ---------- Previous post was at 06:34 PM ----------
It moves 300lbs karts with 2 passengers
  #7
Old 02-05-2017, 07:04 PM
Banned
This will indeed be a grand build!
The Following User Says Thank You to Bbqjoe For This Useful Post:
  #8
Old 02-05-2017, 10:20 PM
chancer's Avatar
chancer chancer is offline
ɔ ɥ ɐ u ɔ ǝ ɹ
You need a Caster Wheel for the Front of the Kart! LOL
Why don't you, go back to your double wide and fry something!
  #9
Old 02-06-2017, 10:48 AM
pRoFiT's Avatar
pRoFiT pRoFiT is offline
Can't buy it?, build it!
Oh wait. you need to argue on the rules then. Says 1 or 2 people machines. not 3 4. But i think in all fairness your go kart with 4 people is reasonable. Looks like fun. Dangerous fun for the passengers in the back!
2016 diygokart Contestant http://www.diygokarts.com/vb/showthread.php?t=33422.
  #10
Old 02-06-2017, 11:09 AM
itsid's Avatar
itsid itsid is offline
by the looks I'm a bit concerned about the kart chassis -excuse me- sidecar flexing under load due to a lack of front wheels, an enormous lever and a considerable amount of weight in front of the pivot (rear wheel)
So may I suggest installing a hidden caster wheel under the front axle beam?
  #11
Old 02-06-2017, 01:41 PM
2SlickNick's Avatar
Really caster?
That would just wobble like a son of a *itch.
I have given the thought of it flexing...
I was thinking of making the some additional under frame bracing. I will put pics up as I go.
I found a good source for info on sidecar construction, I believe this will all be possible.
  #12
Old 02-06-2017, 05:14 PM
itsid's Avatar
Noooo, it won't!
I'm not talking about a shopping cart steel cheap caster, neither one from your desk chair..
I'm talking about a full sized caster wheel like you find on some heavy duty warehouse equipment,
maybe even make one yourself (a mini-bike fork and a kart wheel and another bearing or two)
bracing is okay.. but that layout is ... uhm...
let's say you'd need a full cage to brace that enough with the pivot as far back.
a caster is much slicker (hehe) and if done correctly won't wobble at all
  #13
Old 02-06-2017, 05:46 PM
2SlickNick's Avatar
Okay thanks.
I will take all of this and consideration. And I have been thinking about a full cage. I don't plan on the cart to be that far forward, nothing is welded yet just mocking up.
  #14
Old 02-06-2017, 06:26 PM
chancer's Avatar
ɔ ɥ ɐ u ɔ ǝ ɹ
Post 8
Quote:
Post 10
Quote:
Originally Posted by itsid View Post
So may I suggest installing a hidden caster wheel under the front axle beam? sid
Let the Record Show I suggested this First!
  #15
Old 02-06-2017, 06:57 PM
2SlickNick's Avatar
I know I know!!! lol
The Following User Says Thank You to 2SlickNick For This Useful Post:
chancer (02-06-2017)
  #16
Old 02-06-2017, 07:59 PM
itsid's Avatar
thinking about it... you might even be able to make it a "steering" wheel
just a trailing arm on your bikes front fork, a tie rod and voila... *shrugs*
Ah well.. you'll figure something out
2SlickNick (02-06-2017)
  #17
Old 02-06-2017, 08:43 PM
TeamCheap's Avatar
TeamCheap TeamCheap is offline
COOL project very interesting.
Makes me wonder about the feasibility of making an engine/drive wheel that can be attached to a mini bike frame or attached to a gokart frame or combine the two into something cool like your building so basically you'd have 3 vehicle configurations.
I'm not dancing I'm just waiting to use the restroom
  #18
Old 02-06-2017, 10:26 PM
pRoFiT's Avatar
Needs to be like batmobile. like the sidecar can eject from the bike and drive by itself! id vote for that even if i only had one vote to give.
  #19
Old 02-07-2017, 07:52 AM
2SlickNick's Avatar
I want to post this -----> http://www.haulnride.com/leaner_sidecars.html As I did in my other sidecar build. This is where I am getting most of my info and links from on my leaner style sidecar.
  #20
Old 02-07-2017, 08:54 PM
2SlickNick's Avatar
Welded this 1/4" thick plate for front brace.
Closed Thread
