Closed Thread
Old 03-10-2009, 10:35 PM
killawatt killawatt is offline
tried to get banned
Default chain size
how do i determine the size of my chain its a used yerfdog frame but i dont know the zise of the chain it came with. how can i tell what size it is
Old 03-11-2009, 05:31 AM
r_chez_08's Avatar
r_chez_08 r_chez_08 is offline
Should be in the shop...
you might be able to measure pin to pin?
My process of thought:
Anyone can drive a fast car, few can drive a car fast.
Old 03-11-2009, 05:42 AM
briggsman briggsman is offline
Measure the distance from the middle of the tooth to the next tooth( that is the chain pitch)#35 chain will be a distance of 3/8, and a 1/8 inch diameter pin and a 3/16 roller diamater(the part of the chain that sits down in between two of the teeth.
Size Pitch Roller Dia. Roller width Pin Dia.
#35 3/8 3/16 3/16 1/8
#41 1/2 5/16 1/4 1/8
#40 1/2 5/16 5/16 5/32
#420 1/2 5/16 1/4 5/32
I hope this helps ya out!
The Following 2 Users Say Thank You to briggsman For This Useful Post:
Bluethunder3320 (02-21-2011), killawatt (03-11-2009)
Old 03-11-2009, 05:58 PM
slowkart slowkart is offline
Junior Member
Thanks for the info. So when the chin is installed should it be snug or loose?
Old 03-11-2009, 06:28 PM
Kaptain Krunch's Avatar
Kaptain Krunch Kaptain Krunch is offline
Pro Junk Collector
Should be snug but not tite, you should be able to squeeze it in a bit but it should not have a lot of slop.
Old 03-12-2009, 05:21 AM
the kaptain is correct, to tight will wear out very quickly, and put alot of strain on the clutch and engine side cover, to loose and the chain will fly off!
  #7
Old 03-12-2009, 06:37 AM
ed1380's Avatar
ed1380 ed1380 is offline
Banned
http://www.gizmology.net/sprockets.htm
http://chain-guide.com/applications/index.html
Closed Thread
