Closed Thread
Old 12-26-2008, 02:33 PM
weirdarmadillo weirdarmadillo is offline
Redneck
Default 1/2 inch steel axle?
I am modifying a riding lawn mower to a kart drive line. I have a 1/2 hardened steel rod and all the peices to mount it to the frame and wheels. Would 1/2 be thick enough?
Old 12-26-2008, 03:11 PM
go kart mozart's Avatar
go kart mozart go kart mozart is offline
nope
"Fords are for sissies!, real men wear BOW TIES" - Chevrolet
Old 12-26-2008, 03:31 PM
Russ2251's Avatar
Russ2251 Russ2251 is offline
AZUSA LAWN-BOY E
1" minimum would be industry standard.
Those that can, do. Those that can't, buy a Predator!
Old 12-26-2008, 06:33 PM
Redneck
what if it is a fixed axle w/ single wheel drive?
Old 12-26-2008, 06:38 PM
Kenny_McCormic Kenny_McCormic is offline
Kartless....
1wd might be alright but I would rather go to 1" anyways.
Old 12-26-2008, 06:42 PM
Russ2251's Avatar
AZUSA LAWN-BOY E
My 1 wheel drive kart uses 5/8" axle on drive wheel. I would not want to go smaller than that.
  #7
Old 12-26-2008, 08:52 PM
ed1380's Avatar
ed1380 ed1380 is offline
Banned
sorry to hijack this thread, but if a wanted an axle. would i buy a rod and then have the keys cut or do they sell them like that?
  #8
Old 12-26-2008, 09:06 PM
jr dragster T's Avatar
jr dragster T jr dragster T is offline
Quote:
Depends on what you buy realy. They sell all sort's of keyed shaft at princess auto around here.
  #9
Old 12-26-2008, 09:50 PM
Kartless....
They sell axles keyway cut and turned down/threaded on ends to hold the hubs on.
  #10
Old 12-26-2008, 11:39 PM
Redneck
I hope you dont mind, but im hijacking my thread back because i had an idea and wanted opinions. Im a redneck,so be prepared...i have a 1 inch axle (steel rod), 2-4pushmower tires with bearings, 2 pneumatic tires from harbor freight, 6 inch pulley, 2 inch pulley, and a few belts...mount the mower wheels to the frame and use them for their bearings with holes drilled on the axle for cotter pins to keep from sliding; Mount the big pulley on one of the tires using the bolts from the rims(longer ones); use a welded single wheel drive or use [I]gokartmozarts[I] idea with tractor keys. What do ya think? Ill make a drawing if needed...Thanks...
  #11
Old 12-28-2008, 10:43 PM
Redneck
OK, nevermind...im gonna do it anyways...
  #12
Old 12-28-2008, 10:54 PM
Going 1/2" againts our opinons or going 1" the proper way?
  #13
Old 12-29-2008, 09:39 AM
Redneck
1", Im working on it today, ill try to post pics...
  #14
Old 12-29-2008, 10:15 AM
K Cool.
Closed Thread
