Go Back   DIY Go Kart Forum > Building Plans And Advice > Photo Gallery & Project Log
Closed Thread
Old 07-02-2014, 02:25 AM
karte_m0lim's Avatar
karte_m0lim karte_m0lim is offline
Default gokart Fxr 180
Hi ...
year ago I started my project but do not have much time so ..
I got 5'' wheels, 180 ccm scooter engine (2 stroke) from gillera runner 180 fxr ...
instead of rear wheel I put sprocket and then use conventional transmition via chain.
gear ratio is 40/27 and top speed should be 80 km/h ...
start:
brakes:
sprocketss before :
and after:
pedals:
as original exhaust could not fit, I changed pipe a little bit and probable lost some power...
radiator is from ford tranzit cabin heater :
how should everything fit:
after complete disassembly and checking welds, sanding old paint , primer paint is there:
and after black:
plan is to paint main tubes in orange and put evrything back.
Old 07-02-2014, 07:02 PM
OzFab's Avatar
OzFab OzFab is offline
This is some great work; I like what you did with the sprockets & great idea using a heater core as a radiator
Welcome to the forum
The Following User Says Thank You to OzFab For This Useful Post:
karte_m0lim (07-03-2014)
Old 07-03-2014, 01:45 AM
landuse's Avatar
landuse landuse is offline
I agree. Great work. It must have taken some time working on those sprockets
The Following User Says Thank You to landuse For This Useful Post:
Old 07-03-2014, 01:58 AM
oooouuu yeah .. more than 300 holes on big one ...
start with 4 mm , then 6.5 , 8 ...
thanks for positive comments ..
Old 07-07-2014, 01:28 AM
YouTube: https://www.youtube.com/user/kartem0lim/videos?
Old 07-07-2014, 01:39 AM
landuse's Avatar
That is looking great!! I love the 2 tone colour scheme.
  #7
Old 07-07-2014, 03:05 AM
thanks .. didn't turn out as I expected .. orange just didn't glued on black so have to fix it with brush cause I got no patience to sand it down and respray ..
  #8
Old 07-07-2014, 11:04 AM
firemanjim's Avatar
firemanjim firemanjim is offline
Just kartin' around....
Quote:
I know THAT feeling.....
Good job! But, the sprockets..... Man, that arrangements looks off a little, meaning you will be going super fast on top end, but take forever to get there. Unless I'm missing something......
Slap on the wheels and post a video of it running. I bet it's quite a bit of fun to ride and I'm sure your friends are jealous.....
The Following User Says Thank You to firemanjim For This Useful Post:
karte_m0lim (07-07-2014)
  #9
Old 07-07-2014, 01:34 PM
of course I could be wrong but hope not
in morning I will put some calculations here, now have to put children in the bed :p
this engine has TC inside and 13'' wheels and goes 130 km/h.
if I put 5'' wheel , it will go only 30-40 km/h so have to add some revs on axle
  #10
Old 07-07-2014, 02:58 PM
firemanjim's Avatar
Don't worry about calculations..... Just run it..... I think you are correct.... It HAD a 13" tire, now your going to a 5".... Uhh, get race slicks in a 13" height on 5 or 6" wheels.....
I like this build more n more..... Ready to see it running and what kind of pep it has......
karte_m0lim (07-08-2014)
  #11
Old 07-07-2014, 09:53 PM
OzFab's Avatar
Looking good...
I too wanna see this thing running...
  #12
Old 07-08-2014, 01:55 AM
ok, new calculations ... on some sites I found that top speed of this bike is 108 or 130 km/h ..
tyre used is 130/60-13''.
so diameter is 13'' + 12 cm which is 45,02 cm or 0.4502 m
circumference is Diameter * PI => 0,4502 * 3,141 = 1,413 m
top speed 108 km/h = 30 m/s
rev on axle = 30/1,413 = 21,77 (1/sec) = 1276 rpm
sprockets on engine side is 40 and on gokart axle is 28 tooth, ratio is 1.428
so gokart axle will do max 1276 rpm * 1,428 = 1822 rpm => 30 (1/sec)
gokart wheel is 5'' and whole tyre is 10" or 25.4 cm or 0,254 m in diameter
circumference is 0,254* 3,14 = 0.797 m
top speed sholud be 0,797 m * 30 (1/sec) = 24 m/s or 87 Km/h
if bike top speed is 130 km/h then kart will go 101 km/h ...
if that is case, then I sholul check welds again ...
  #13
Old 07-08-2014, 02:03 AM
there is some updates,
chain is up:
radiator:
brakes with wire:
as motor starter was on left side gotta change it and put it on right side :
kart with tyres on (toe and camber are not seted up yet):
new tyres waiting to be burned:
  #14
Old 07-08-2014, 02:21 AM
well, here are some old videos , back in 2010 when I bought second hand gokart..
same engine was on, but chassis was horrible, cuted and welded so many times. ..
also, there was no exhaust, just pipe and finally i got crashed and twisted chassis beyond repair...
took two years to start build new one...
videos are poor quality, specialy this from down hill run without engine ...
downhill:
my test driver:
  #15
Old 07-08-2014, 07:05 AM
zbuck zbuck is offline
Smile
Nice job. But I am not big fan of having the gas tank above my head. If it were me, I would put it under the steering tower and add a fuel pump.
The Following User Says Thank You to zbuck For This Useful Post:
  #16
Old 07-08-2014, 07:22 AM
well, I like my balls more than head :p
trying to keep simple, but good sugestion
  #17
Old 07-08-2014, 07:43 AM
firemanjim's Avatar
lol I almost spit out my tea when I read that.......
  #18
Old 07-08-2014, 07:52 AM
:p
If I put pump, do I need another pipe for returnig unused fuel or different carb?
  #19
Old 07-08-2014, 08:00 AM
firemanjim's Avatar
No return line needed. You only have the fuel line with a pulse pump in the middle somewhere . That has a line for a pulse (suction) from a vacuum source on the engine, like the manifold. It only pumps what you need.....
  #20
Old 07-08-2014, 08:14 AM
Planed to put choke and kill switch between legs...
But definitly give me something thinking...
Closed Thread
