Reply
Old 11-21-2008, 02:36 PM
Richard III Richard III is offline
Default Intallsing an Start Motor to my Engine
ok I am installing an electric starter (Tecumseh 29965) to my Tecumseh H70-130205D engine. I am going to have a 12v battery that is charged using the AC stator inside the flywheel by having a rectifier in line to the battery. Then the starter motor will be turned over by a switch that is conneted to the battery and the startor and I belive that the negitive side of the battery is conected to the enge so the negative side of the battery is connected to the engine. I am confused on how I wire it up and how to know if my Stator (altenater) creats enogh power to charge the battery.
Thanks Ricky
Ricky =P
"Drive it like you don't own it"
Old 11-21-2008, 06:26 PM
kibble's Avatar
kibble kibble is offline
I banned myself
You got any pics or model numbers? Would make it easier to figure out.
"At the enrichment center we believe that if at first you don't succeed, you fail." GLaDOS - Portal
Old 11-22-2008, 05:02 PM
I put the model number in my first post. The Starter motor is a Tecumseh 29965 and the engine is a Tecumseh H70-130205D and i can get some pics later on or tommrow. What would you want for pics.
Thanks Ricky
Ricky =P
Old 11-22-2008, 05:32 PM
Kenny_McCormic Kenny_McCormic is offline
Kartless....
The starter need a HEAVY wire and a solenoid to engage it, you cant use a switch directly.
Old 11-22-2008, 05:33 PM
kibble's Avatar
I banned myself
Quote:
Thanks Ricky
Oh, my bad, I mis-read it and thought it was the engine number.
Old 11-24-2008, 01:06 PM
ok so i still dont get ...
1) how I am going to wire up the rectifier and the regulator
2) how do i connect the stator
3) how can i tell what i should be getting for output voltage.
thanks for your help so far,
Ricky
Ricky =P
  #7
Old 11-25-2008, 02:46 PM
another qeustion I have is what size battery should I use for the tecumseh 29965 starter. 12volts but how many amps?
Thanks Ricky
Ricky =P
  #8
Old 11-25-2008, 04:01 PM
kibble's Avatar
I banned myself
Ricky
1. Rectifier/regulators usually have some sort of input a ground and an output.
2. I don't know as I'm not familiar with that type of equipment
3. You should be getting something about 14V output if it's regulated, possibly more if it's not. Assuming it's meant for 12 system.
Thanks Ricky
The larger the amperage, the more power it will provide to the starter for cranking. I would say minimum of a 7Ah lead acid battery.
  #9
Old 11-25-2008, 04:07 PM
scar's Avatar
scar scar is offline
muahahahahahaha
you have to remove the flywheel to hook up the stator u should see 4 holes (i think it was 4) where a fine thread screw would fit all you do is screw it on (with the right screws and make sure your wires are kept at the top out of the way) then put the flywheel back on and plug it in
Reply
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
