i REALY need a few parts for my LB. the #'s are 7229 8785473
first for sure is one of those on off switchs' that twist about 90 degrees to turn it on/off looks like this http://i276.photobucket.com/albums/k...et/poooooo.jpg and i may need the coil for but im not sure about that if any1 has either of these parts plz let me know either by PM or reply this post thanks! |
Switch part number is 681656 or 104-4446.
Coil part number is 681578 or 100-2949. Parts available here: http://www.m-and-d.com And here: http://www.partsandservice.com
"You can run...but you can't hide." |
holy crap that stuff is expensive
russ, could you tell me waht kinda LB i have as model, year, hp ect? |
Serial number indicates that it's a 1978 and is a model F engine.
Horsepower ratings are a little foggy. I have model F's that are 4 hp while others are 4.5 and 5. All the engines are identical (bore, stroke, induction) to each other so I do not understand why the hp ratings are so different. They all behave like 4.5 hp.
do you think it could be the carbs that make a HP change?
BC on this one i have a small plastic carb as upposed to the other F had a bigger one that was metal |
All the carbs I have (and have seen) all have the same size venturi and bore sizes regardless of what was used to construct them. The plastic carbs are made of MinlonŽ.
#7
minlon?
thats a sort of plastic right? i am still needing LB parts if anybody is wondering please dont take this in the wrong way Mr. Russ but im just gonna keep looking unless i cant find anything else |
#8
I believe your CDI pack is 'ground to run' which is an early design.
Most L-B packs are 'open to run'. Both are essentially the same, they are just 'turned on' in different ways. Try by-passing switch and check for spark. If no spark, try baking coil. Most of the time it will resurrect a dead coil. This should be considered a temporary fix, although I have a few that have lasted a couple of years.
#9
ok
so some run with a ground and some run without i already baked it BC i thought there was probebly a problem with it and i didnt think it could hurt it so your saying just bypass the switch with a straight wire and if that doesnt work try bypassing the switch with nothing? i'll try it thanks alot Mr. Russ |
#10
Mr. Russ
do you think this LB would be a good one to make a kart engnie out of? |
#11
well um i tryed it and it gave me 2 back to back sparks then it stopped and i messed with everthing and still couldnt figure out wat was wrong
#12
Quote:
Quote:
Quote:
I have also seen them new for around $29 plus shipping. Check around at local lawn mower repair shops. Ask if they have any good used ones they would be willing to part with. Usually they have a pile of mowers waiting to be scrapped for aluminum content. Won't hurt to ask.
#13
so outa those two coils that you have on those websites you gave me
does it matter witch one i get? will this coil fit? http://cgi.ebay.com/Lawnboy-Lawn-Mow...1%7C240%3A1318 |
#14
Quote:
Quote:
#15
ok
thank you sooooo much Mr. Russ i found a switch on ebay for about $13.00 shipped if i win it but i have a strong feeling i will win them both |
#16
Why are you going all out just to find a stock switch? Just go to radio shack and buy a toggle or something.
#17
Mr. Sayre wants original and wants it right as I do with any restoration.
Any hack can get something to work. The hard part is getting it right. Bigger payoff in the end. I commend him.
#18
Sooooo, now we're all hacks, I see? LOL
"At the enrichment center we believe that if at first you don't succeed, you fail." GLaDOS - Portal |
#19
Didn't say that, but a pitiful few of us are not.
#20
its BC i thought about making this into a kart engine but decided not and there reasons are
it has a pretty much rust free deck, nothing is damaged and i need the money so im just gonna wait to get a LB that is damaged that way i dont feel bad about taking apart a great LB the way i make my money is buying non working mowers and/or cheap mowers off of craigslist and garage sales fix 'em and ssale them later and those lawn boys sell REALY fast down here |
| Thread Tools | |
| Display Modes | |
