Closed Thread
Old 08-27-2013, 07:37 PM
dirtroaddrifter dirtroaddrifter is offline
Junior Member
Default torque converter belt slipping
I have noticed that my belt on the torque converter is slipping. I'm almost positive that the belt that come with it isn't the right one but I wanted to ask just to be sure. Its a comet 30 torque converter on a Murray explorer
Old 08-27-2013, 08:09 PM
OzFab's Avatar
OzFab OzFab is offline
You are correct, that looks like a simple V belt, nowhere near suitable. There's a belt guide link around here somewhere but, I can't seem to find it...
The unit appears to be a standard TAV 2 setup, measure the distance from centre to centre to be sure but, someone else who knows a bit more should chime in soon.
Sorry I couldn't be more help
Old 08-27-2013, 08:58 PM
itsid's Avatar
itsid itsid is online now
TAV2 has an asymetric belt (18 on one and 2.5 on the other side)
with a top width of 3/4" and an OD of 27 3/8"
the original part# is 203589A
similar belts are (AFAIK)
HOFFCO/COMET 203589A,
OREGON 84-027,
PRIME LINE 7-07895,
ROTARY 8487,
SUNBELT AC-589,
SUNBELT B1AC589 3/4"W x 27 3/8"OD
Old 08-27-2013, 11:50 PM
maximu5 maximu5 is offline
Junior Member
This might help: http://www.gokartsupply.com/identify.htm
Old 08-28-2013, 12:37 AM
landuse's Avatar
landuse landuse is online now
Here is the link for finding out what belt you need. All you need to know is the center to center distances between the driver and driven, and also the diameter of the driven
http://www.gokartsupply.com/tcbelts.htm
Old 08-28-2013, 01:20 AM
OzFab's Avatar
Thanks guys
  #7
Old 08-28-2013, 05:05 AM
Doc Sprocket's Avatar
I believe you can add Manco #5959 to the above list, but it is preferable to start with the Original Comet part number.
Just to reinforce the statement: You do indeed appear to have a V-belt. The pic's a bit blurry to me, but I think it's a 5L or B-series belt. There is no standard V-belt that will allow your CVT to function correctly. Pop on the proper belt, and you're off to the races.
  #8
Old 08-28-2013, 07:56 AM
Junior Member
I really appreciate all the help I'll measure the distance between driver and driven then order the correct belt now
Closed Thread
