Closed Thread
Old 03-21-2013, 05:05 PM
UPTON O'GOODE UPTON O'GOODE is offline
Default ACE Maxxam 150 2r
I just bought a used Kart for my daughter. I was hoping someone out there has one and could post a pic of what the wiring should look like under the dash. It seems the previous owner replaced the keyed ignition switch with a toggle switch and a push button. I tried contacting ACE Sports to no avail. Numbers don't work and email address is invalid.
PLEASE HELP. She comes home SATURDAY morning and I want it up and running by then. Burning the midnight oil.
Engine turns over just fine. No spark at plug. New coil. When I disconnect the two wires at the coil, I get voltage at the those two wires when I push the start button.
Any help would be appreciated.
Old 03-21-2013, 05:08 PM
Doc Sprocket's Avatar
Welcome to the forum, LOVE the username!
The coil is energized ONLY when pushing the start button? Sounds like the guy got confused. Coil should energize with the on/off switch (duh) and the start button should have no effect on the ignition circuit.
Old 03-21-2013, 05:09 PM
I'll check that
Old 03-21-2013, 05:12 PM
Yep 7.5 vdc
Old 03-21-2013, 06:18 PM
jamyers's Avatar
jamyers jamyers is offline
My google-Fu is strong tonight!
Owners Manual: http://www.acesportsonline.com/manual_maxxam.pdf
Setup Instructions: http://www.acesportsonline.com/Set_U...ion_Maxxam.pdf
Service Manual (with wiring diagrams, page 70): http://www.scootermasters.com/manual...ice_manual.pdf
TexasTerror: http://www.diygokarts.com/vb/showthread.php?t=14872
Yerf-Dog: http://www.diygokarts.com/vb/showthread.php?t=19878
Old 03-21-2013, 06:24 PM
Way to go, Jammy! (That's why we pay him the big bucks!)
The Following User Says Thank You to Doc Sprocket For This Useful Post:
jamyers (03-21-2013)
  #7
Old 03-22-2013, 01:58 AM
landuse's Avatar
landuse landuse is online now
Quote:
Hey.....are we getting paid??
  #8
Old 03-22-2013, 05:29 AM
Truly appreciate the help.
I found the online manuals last Monday. Sadly, I don't have a computer at home, much less, a printer.
Anyway. I found another rogue wire. This one is from the CDI (could be my whole problem).
So my new question: can I reuse the Molex connector that the wire came out of? If not, where do I find new ones? Auto parts house, or electrical supply house.
  #9
Old 03-22-2013, 06:26 AM
jamyers's Avatar
Quote:
My salary just doubled! Yours didn't?!?
(2 x 0 = 0, LOL)
  #10
Old 03-22-2013, 06:28 AM
jamyers's Avatar
Ought to be able to get a crimp connector at any auto parts, hardware, or electrical shop.
The Following User Says Thank You to jamyers For This Useful Post:
UPTON O'GOODE (03-22-2013)
  #11
Old 03-22-2013, 06:32 AM
landuse's Avatar
Quote:
(2 x 0 = 0, LOL)
So THAT was the unknown deposit into my bank account. I was wondering...
  #12
Old 03-22-2013, 07:58 AM
realfast89gt's Avatar
realfast89gt realfast89gt is offline
Kart Krazy!!
Bring the old one to a parts store and have them match it up. Have to do this occasionally when fixing automotive wiring. Much cheaper than buying a whole new one, normally you can find a connector.
The Following User Says Thank You to realfast89gt For This Useful Post:
  #13
Old 03-22-2013, 04:06 PM
Fixed the CDI WIRE...
Again, I get voltage to the plug coil but no spark...
I'm strugglin'
  #14
Old 03-22-2013, 04:08 PM
And I printed the manual
Thx jamyers
  #15
Old 03-22-2013, 04:15 PM
Sure could use some over the phone help...
Or help, with pics
  #16
Old 03-22-2013, 04:18 PM
If I am getting voltage at the plug coil wire, shouldn't it fire?
  #17
Old 03-22-2013, 04:32 PM
Let me re-iterate...
If I'm getting voltage at the two wires that go into the plug coil (when they're disconnected from the coil) shouldn't it fire?
  #18
Old 03-22-2013, 04:36 PM
In theory. How do you know you don't have a defective coil? EDIT- Or a bad plug?
  #19
Old 03-22-2013, 04:42 PM
They're both brand new. The manual says that I should be getting an open reading on my multimeter from one end of the coil to the other. I do.
  #20
Old 03-22-2013, 04:46 PM
Do you have another plug to try with? Or a spark tester? I have had bad plugs right out of the box, and have heard many accounts of bad new coils. Don't assume anything- test.
Closed Thread
