Closed Thread
Old 01-29-2013, 02:33 PM
IceMan198753 IceMan198753 is offline
Default T-Bucket style Go Kart
Hi ya'll
I am new here and new to the hobby
I am trying to come up with an idea for a T-Bucket style Go Kart. I want the engine in the front and it to be RWD. I want it manly just to drive around with (pavement, NO off-road) and to look and function like a real t-bucket.
I am starting this from NOTHING but a 20hp Kohler engine with a vertical output shaft. SO any input and information and opinions are welcome.
The engine was FREE so that is why I want to use it. I would hate to have to buy a new/used one. And I think the vertical shaft will give me a challenge.
Info about...
Building material
Frame design
Drive train
Wheels and tires
Axles
Bodies
...and the list goes on.... would be very helpful.
Thanks,
David.
Old 01-29-2013, 03:54 PM
EEngineering EEngineering is offline
formally infidel
A vertical shaft is going to be hard to use.
May want to rethink the engine first.
Other than that shouldn't be hard.
Old 01-29-2013, 03:55 PM
What would be a good/cheap engine?
Old 01-29-2013, 04:03 PM
formally infidel
Depends on what cheap is?
I would use a harbor freight 6.5 for $119.00 new
And gear it to what speed you want.
They are good strong engines with a warranty.
Old 01-29-2013, 04:11 PM
DS13's Avatar
DS13 DS13 is offline
Annoying the Neighbors!!!
Quote:
Originally Posted by IceMan198753 View Post
Hi ya'll
You may have a problem doing the engine in the front and it being RWD.
using a vertical shaft will be hard to convert. but not impossible.
Two wrongs may not make a right but three lefts will
http://www.diygokarts.com/vb/showthread.php?t=16543
Old 01-29-2013, 04:12 PM
I found this one! What do ya'll think of this one?
http://gokartsusa.com/Honda-Gokart-E...nibike-65.aspx
  #7
Old 01-29-2013, 04:13 PM
DS13's Avatar
honda is always reliable and mods are abundant.
  #8
Old 01-29-2013, 04:17 PM
formally infidel
Anything is possible! LOL
  #9
Old 01-29-2013, 04:18 PM
DS13's Avatar
well yes, if ya have patience, money, and the know how!
  #10
Old 01-29-2013, 04:22 PM
RadioFlyerrr's Avatar
RadioFlyerrr RadioFlyerrr is offline
Someone please correct me if im wrong , but isnt that basically a harbor freight engine ? from what I understand these clones are not all that different from each other . This one just seems to be more expensive .
  #11
Old 01-29-2013, 04:24 PM
formally infidel
I agree to much money for the same thing as a harbor freight engine.
  #12
Old 01-29-2013, 04:25 PM
Or get this one
http://www.harborfreight.com/horizon...7hp-69730.html
With this upgrade kit
http://gokartsusa.com/Builders-Parts...160-GX200.aspx
  #13
Old 01-29-2013, 04:57 PM
Doc Sprocket's Avatar
Iceman- Very, VERY cool idea. And one that I have been playing with on paper for quite some time.
I batted around the idea of using a vertical shaft engine. Easy-peasy, really. Think green. As in grass. As in lawnmower...
Vertical front engine, using a belt and pulley system running rearward to a Tecumseh-Peerless 700 (or equivalent) lawn tractor transmission that has been race-prepped. The 700 is a transmission (not a transaxle) that has a vertical shaft input, and a horizontal shaft output. The output would then be chain and sprocket to a live rear axle. Done like dinner.
You could use a centrifugal clutch if you like, or just a manual belt tensioner for clutching. The benefits include having a multi-speed transmission with reverse. Very carlike in operation...
The Following 2 Users Say Thank You to Doc Sprocket For This Useful Post:
hardin (04-25-2013), IceMan198753 (01-29-2013)
  #14
Old 01-29-2013, 05:26 PM
OzFab's Avatar
OzFab OzFab is offline
Sorry guys but, I'm with TS on this one: thousands of lawnmowers work with this setup so, I can't see why not.
Good luck with it Iceman; I look forward to seeing this come to life
  #15
Old 01-29-2013, 05:37 PM
Quote:
Hundreds of thousands. And LOTS of racers, too- as long as the components used are up to the task and properly prepared.
  #16
Old 01-29-2013, 05:53 PM
machinist@large's Avatar
machinist@large machinist@large is offline
I'm with TS and Fab as well; all the parts you need to put that 20 HORSE POWER ENGINE to good use is reasonably readily available. And lets not forget, if you are looking to go the T- bucket route, you're doing it for a little bit of style. Now, which looks better on the style front; an import 7 hp single, or a US built 20 hp twin?
Just my two cents.......
Pat
  #17
Old 01-29-2013, 06:35 PM
mister twister's Avatar
mister twister mister twister is offline
TOWER OF POWER is my name
i agree. not that you need more validation. front engine rear dive with a manual shifter and belt tensioner clutch? about as t bucket as it gets.
i got a couple outboards in the basement jus' in case of a flood
  #18
Old 01-29-2013, 06:39 PM
How would I make that faster? 25-30mph
  #19
Old 01-29-2013, 06:43 PM
What size live axle should i get? I don't know how they size axles and do u need bearings to hold it?
  #20
Old 01-29-2013, 07:00 PM
1", and yes. Give us some time, and we can examine gearing. With that set-up, there's a bit more to it.
The Following User Says Thank You to Doc Sprocket For This Useful Post:
chain (02-03-2013)
Closed Thread
