Selling out and figured I would offer it here too. Enough to put together two new karts and 90% of the other two. Asking $4500 OBO
New Bicknell Stuff: 4 New Frames made by Bicknell. - 1 Black powedercoated - 2 Red powedercoated - 1 White powdercoated 10 BRP4337 Aluminum Spindle Housing 6 BRP4341 Left Front Spindle Assembly 6 BRP4342 Right Front Spindle Assembly 16 BRP4324 Plastic Bumper Spacer 3 BRP4347-2 Rear Axle Bearing Retainer 10 BRP4347 Rear Axle Bearing Retainer 8 BRP4328 1 1/8" Clamp for Torsion Bar 4 BRP4329 Seat Brace 2 BRP4326 45 Degree Strut 2 BRP4330 1 1/8" Seat Brace 2 BRP4327 90 Degree Clamp 8 BRP4325 Blank Steel Clamp Half 4 BRP4354 Brake Rotor Mounting Hub 1 1/4" 4 7" Dia. X 3/16" Slotted Steel Rotor 1 BRP4355D 7" Dia. X 3/16" Drilled Steel Rotor 4 BRP4397 Throttle Cable 6 BRP4390 Brake Pedal 6 BRP4393 Gas Pedal 2 BRP4357 Sprocket Hub 6 BRP4367 5/8" Steering Shaft Assembly 6 BRP4391 16" Brake Rod 6 BRP4394 21 3/4" Gas Pedal Rod 10 BRP767 1/2" Aluminum Wheel Spacer 4 BRP765 1/4" Aluminum Wheel Spacer 6 BRP4395 Spring 3 BRP181A 5/8" Aluminum Collar 12 BRP4333 Aluminum Front Hub 12 BRP4351 Aluminum Rear Hub 2 BRP4360 1 1/4" Rear Hub 2 BRK50-5010 5 Qt. Plastic Fuel Tank 4 BRP4413C Chrome Right Side Bar 4 Chrome Left Side Bar 4 BRP4410C Chrome Front Bumper 4 Chrome Rear Bumper 4 BRP4097-44 Axle - .250 Wall 44" Chrome Moly 4 BRP44456 Aluminum Floor Pan 4 BRP4440C Bolt Kit for 4440C Bumper 13 BRP4349 1 1/4" Aluminum Split Collar 14 BRP4338 Adjuster King Pin 8 BRP4340-10.5 3/8" x 10 1/2" Tie Rod 4 BRP4366 Steering Hub Collar Other New Stuff: 40" Aluminum Axle 300'+ Brake Hose 8 Rear Axle Bearings 5 MCP Master Cylinders 6 MCP Calipers Digitron 32k32 Gauges 2 6 ½ x 10" Circle Wheels 2 6 ½ x 6” Circle Wheels 2 Adjustable bearing cassettes Steering Wheel 6’ #35 chain 1 set of Bridgestone tires White CIK Body 2 Sprockets, #35 63 & 65T Spark Plugs: 1 Splitfire SF409C 2 ND W27FS-ZU 1 ND W31FS-ZU 2 NGK B9HV 1qt Yamalube 1qt Burris HiRev 2 8oz chain oils 16oz Brake fluid 1 Brake bleeder kit Tons of nuts and bolts (at least enough to put together a few chassis) Motors: 2 fresh blueprinted KT100‘s with carb, Horstman DXL clutch, 4hole can muffler Used Stuff: 2 sets of 5” Douglas wheels 2 Sets of Used Tires Horstman Steel Nitro Clutch Coleman starter Large Lightning Light seat 3’ Fuel line 2 Sprockets, #219 71 &77T Spark Plugs: - 4 ND W27FS-ZU - 2 ND W24FS-ZU - 1 Autolite 4092 Pictures of it all are here: http://s492.photobucket.com/albums/...racing/sellout/ Would like to sell it all as a package, or trade for something of equal value. I’m open to any offer, so let me know what you have. |
Its Supercross10! Thank You.
Please Look At My Thread! Its Supercross10! Thanks Bud.
Hi, i really need a master cylinder and rear caliper for my build hopefully you will want to split and sell your package seperatly
if so possibly a frame and also interested in other parts if can get a frame thanks so much |
can email me tho i prob will forget to check this
Lynder222222@yahoo.com im a newbie so i dont knwo what PM's are or anything |
hey buddy you might want to check when this was posted.........
anderkart-"Hey dude your Font is showing." |
#7
HAHAHAHAHAHAHA I'm sorry this made my night lol, a one year necro....in all my interweb dayz...
didn't you ever just want to take an ordinary ole thing and slam some huge mofo engine on it just to say you did it? |
#8
haha wow didnt even check for it haha im new come on hahah
#9
Its cool when your new you get one chance but after that down in the cellar for you!
| Thread Tools | |
| Display Modes | |
