Closed Thread
Old 10-24-2012, 08:36 AM
Flesher427 Flesher427 is offline
1st Degree
Default Carb Q
My son bought this for his GX200. After he installed everything there really wasn't a noticable difference over the stock parts. Does the bigger jet and different emulsion tube require the air/fuel mixture screw to be adjusted in order to see some performance improvement?
Old 10-24-2012, 06:22 PM
jamyers's Avatar
jamyers jamyers is offline
Yes, I'd expect you'd need to re-adjust the mixture screw, although it only/mostly affects idle and just off-idle.
Have you made any other mods to the engine, specifically for reaching higher than stock rpm? I also wouldn't expect to see a gigantic improvement with those parts until the engine revs up above 3-4K and higher. At lower rpm the stock intake and exhaust aren't much of a restriction, and header pipes need some rpm to be really effective.
Don't get me wrong - those parts will definitely help, but just not hugely all by themselves.
TexasTerror: http://www.diygokarts.com/vb/showthread.php?t=14872
Yerf-Dog: http://www.diygokarts.com/vb/showthread.php?t=19878
The Following User Says Thank You to jamyers For This Useful Post:
Flesher427 (10-25-2012)
Old 10-25-2012, 07:14 AM
1st Degree
Thx for your reply. The motor is all stock now with the exception of the parts above. He wants to remove the governor and install stiffer valve springs next.
Old 10-25-2012, 10:00 AM
jamyers's Avatar
OK, then you'll notice a difference. Well, not really a difference unless you put the stock intake / exhaust back on and then try to rev it higher...but that would be silly!
Anyways, if you haven't already, be sure to check out the "Governor Removal Reality Check" thread here: http://www.diygokarts.com/vb/showthread.php?t=16518
Have fun!
Old 11-02-2012, 06:24 PM
1st Degree
Thx... we'll remove it in the spring
Old 11-02-2012, 06:30 PM
Doc Sprocket's Avatar
Quote:
Not a good idea!
  #7
Old 11-02-2012, 06:43 PM
souperman000's Avatar
souperman000 souperman000 is offline
Quote:
Originally Posted by toystory_4wd View Post
Not a good idea!
Have a read, it will explain Toystory's post.
It's hard to help people that won't help themselves.
  #8
OzFab's Avatar
OzFab OzFab is offline
Not a good idea!
Governor yes, valve springs, not before you upgrade the internals...
Nothing is impossible to fix if you have enough time, money & patience
2013 Build-off Winner http://www.diygokarts.com/vb/showthread.php?t=21076
  #9
Old 11-04-2012, 01:54 PM
1st Degree
Roger that
Closed Thread
