Closed Thread
Old 07-10-2012, 03:44 PM
qtband's Avatar
qtband qtband is offline
Default Centrifugal Clutch Repair?
My friends 1" cent. clutch is engaging as soon as you pull the starter rope. I took his off and replaced it with one of mine and the kart worked fine so idle was not the problem. If I spin the clutch I can hear it and feel it grabbing. I took off the retaining clip to expose the shoes, but how does the rest come apart?
I asked God for a go-kart, but God doesn't work that way. So I stole one and asked for forgiveness.
Old 07-10-2012, 04:59 PM
Doc Sprocket's Avatar
Perhaps the spring is shot, or maybe the bushing. Can you see a C-clip holding the outer plate on?
Old 07-10-2012, 05:33 PM
qtband's Avatar
Yes, I took that clip off and removed the bell. Now what?
Old 07-10-2012, 05:36 PM
Depends on clutch type. May well be another C-clip in there.
Closed Thread
