Hey guys i was welding yesterday and when i woke up this morning my eyes were red and i felt like they are filled with sand and this is because i am using a cheap normal welding helmet in conclusion i want to buy an auto darkening one so what are the best helmets to buy
Thanks |
Using a standard, fixed shade welding helmet should NOT cause these symptoms. Something else is wrong. Are you performing tack-welds unprotected? Is there a crack or gap in your mask, letting the light through?
The Manual- "Just the manufacturer's opinion of how to put this together."- Tim "The Tool Man" Taylor Put down the wrench, and come out with your hands up!- Me! Wrench, Wheel, Wreck, Repeat... |
Thats not fault of the helment (much)
What shade lens are u useing That would be the issue Also blind tacking is a big no no (closing your eyes to quick tack) Otherwise if u guys get CIG welders over there They make good cheap helments Most of the welders Iv met use them as they are reliable
Buggy building Fast, reliable, cheap Pick two |
yes yesterday i was tack welding without putting the helmet
Quote:
My friend, you only get one pair of eyes. Do not abuse them like this!
The Manual- "Just the manufacturer's opinion of how to put this together."- Tim "The Tool Man" Taylor Put down the wrench, and come out with your hands up!- Me! Wrench, Wheel, Wreck, Repeat... Last edited by toystory_4wd; 07-10-2012 at 10:33 AM. |
| The Following User Says Thank You to toystory_4wd For This Useful Post: | ||
Ghanem (07-10-2012) | ||
#7
iv got one from harbor freaght it was like 20 dollors and works great use it every time i weld i have got used to it so when i try to weld with a not ato darking i cant weld very good
#8
FLASH BURN Or A EYE BALL SUN TAN . Auto Dark Hood is the way to go.
#9
You can easily tack without a helmet. Sure, it's not advisable, but just to put down a tiny tack weld, it's do-able. I'm guilty.
#10
Yup i'll get an auto darkening one now
#11
Fixed shade helmet actually protects ur eyes better than Auto darkening helmet. I have both. I have a Hobart fixedshade helmet thats a #12 i think. I dont use it when I weld cause I cant see **** with it. I use it for bystanders and helpers.
My autodarkning helmet is a cheapo northerntool one that I payed $40 but it works like its suppossed to. What amperage are u tack welding with? high aparage tack welds can be enough to burn ur eyes. U welding with stick? Stick welders are generally high amps. When I worked on drill rig my tool pusher was welder together casing (pipe) and I wasnt even looking at the arc and burned my eyes. Pain like crazy, cant imagine what it would of been like if I was actually looking at the arc. |
#12
Quote:
thanks for the advice everyone |
#13
i have the harbor freight one. i love it
has sensitivity setting fast/slow something and a know on the side that somehow adjusts how dark the lens gets. up a little too high and i cant see a thing, set just right i have a perfect view without any flash burn in my eyes. you can easily get flash burn even if you just tack with eyes closed and 1 or 2 flashes with your eyes open can result in what i felt as needles coming out of my eyes for hours straight |
#14
Ive had flash burn now 5-6 times, DONT tack weld without a shield. Last time I got it, I was standing 10 feet away from someone plasma cutting, and I wasnt directly watching him either. be careful
#15
I believe the Ark is some thing like ten time brighter than the sun. Also you can get tan on eyelids from ark flash. If you are doing Alum you can get a nasty pink sun tan on most any part of your skin that Is right in front of the Ark . Sitting in a dark room with sun glasses on is not a lot of fun.
#16
i watch people weld all the time sometimes im 8 feet away i no i shouldnt tho
#17
Quote:
On the occasion that I accidentally look at an arc it ****s with my eyes. Wish I could find a $20 auto darkening one.
My process of thought: ![]() Anyone can drive a fast car, few can drive a car fast. |
#18
I must admit, I'm also guilty of tacking without a helmet on occasion, only because my current helmet sux. I did have a great auto helmet but the battery died from lack of use. I've only ever had full on flash once (that was enough) but I've often had sunburned eyelids (OOOOOUUUCH!)
In saying that, I do not recommend welding or even quick tacking without a helmet
There's no better feeling than seeing something you made work ![]() Nothing is impossible to fix if you have enough time, money & patience |
#19
Here's a tip for the non auto dark user's . Rest Tig cup on what you are welding, Tungsten should very close to object that Is being welded to strike arc .
#20
Quote:
Most of the people here can't afford a GTAW machine. The majority are using either SMAW, GMAW, or FCAW.
ASE Certification (Engine Repair, Brakes, Electrical, Engine Performance), pending |
| Thread Tools | |
| Display Modes | |
