Closed Thread
Old 06-23-2012, 05:27 AM
MarkM MarkM is offline
Junior Member
Default HELP!! robin subaru throttle linkage
I just bought a manco fox vortex for my son, the kart sat for several years before i got it. So here is the problem the owner before me removed the carb and lost it. I have a new carb but what i cant figure out is how the linkage on the top of the motor connects to the carb ?????? the engine is a robin subaru 169cc 6.5 hp motor i cannot find any pictures or diagrams online please help thanks guys
Old 06-23-2012, 06:44 AM
OzFab's Avatar
OzFab OzFab is offline
Post some pics of your carb mounted so we can see how it all fits; a picture tells a thousand words
Old 06-23-2012, 07:14 AM
Doc Sprocket's Avatar
Yeah- what he^ said! Welcome to the forum!
Old 06-23-2012, 08:59 AM
Junior Member
Ok thanks guys i will try to get pictures tonight maybe i will get lucky and somebody will have the same set up and be able to get me pics of thiers I am just concerned about safety, I really dont want to " rig " anything
Old 06-23-2012, 09:15 AM
anderkart's Avatar
anderkart anderkart is offline
Mark, this isnt my kart but here's the best pic I could find:
Old 06-23-2012, 01:31 PM
Junior Member
that looks like my set-up but to hard to see where everything goes i do appreciate the pic though
  #7
Old 06-23-2012, 05:36 PM
Junior Member
cant get a picture to load off of my phone i can text it if anyone can help me please
  #8
Old 06-24-2012, 05:09 PM
Junior Member
ok think i got it hope this helps thanks guys my son also thanks all of you
  #9
Old 06-24-2012, 09:26 PM
anderkart's Avatar
You'll find diagrams of all your govenor and carb linkage/springs by downloading the Illustrated parts listing at this link:--> http://www.arkansas-ope.com/ROBIN_SUBARU_IPLS.html
  #10
Old 06-25-2012, 05:02 AM
Junior Member
Ok checked that out and i now know that I am missing a spring but what links the actual throttle cable to the carb(what moves the butterfly). The only linkage hooked to the butterfly now comes from the governor. I'm sure the answer is right there but I'm just not getting it.
  #11
Old 06-25-2012, 09:54 AM
anderkart's Avatar
Quote:
That's correct. Your karts throttle cable connects to the govenor. Then the govenor linkage connects to your carbs butterfly. That's the only way the govenor system could limit engine RPM.
But if you want, you could remove your engines govenor system, then conect your karts throttle cable directly to the carbs butterfly. Here's some info about doing that mod: http://www.mokaioutdoors.com/viewtopic.php?f=10&t=254
  #12
Old 06-25-2012, 11:33 AM
Junior Member
I understand what you are saying but the throttle cable hooks into this mechanism that has springs and rods on it but nothing from the cable or the mechanism hooks the the arm on the engine governor or the butterfly on the carb thats where a good picture would come in handy
  #13
Old 06-25-2012, 03:38 PM
anderkart's Avatar
Check out this page, then click on all the pics to view larger sizes: http://www.ebay.com/itm/Robin-Subaru...-/390382545984
Here's some google Images:
The Following User Says Thank You to anderkart For This Useful Post:
Peteypooldude (07-21-2013)
Closed Thread
