Go Back   DIY Go Kart Forum > Building Plans And Advice > Photo Gallery & Project Log
Closed Thread
Old 06-20-2012, 07:32 AM
JamieH's Avatar
JamieH JamieH is offline
Junior Member
Default DIY dune buggy/go cart 1.4 nissan sunny engine
ok so where do i start.. I started this build back in january 2010 (i think) i decided after i got a new field car to replace my 1989 nissan sunny that it would be a shame not to do something with the engine which was pretty good and 86hp stock so plenty of power for a cart which will hopefully come in at under 500kg..
So after getting my father on board (metal fabricator ftw ) as i was just gone 16 at the time and this was going to be my first build of any kind, we stripped the engine out of the car. Unfortunately dad had already cut the wishbones, track rods and one drive shaft as he wanted the hubs for a trailer leading to difficulties down the line...
Ok so the first step was to obviously make the frame, we searched the internet looking for a design that we liked and then we used ratio's etc to get rough demensions, then it was time to start fabricating
our state of the art CAD system
might be hard to see but we used chalk on the floor and used a centre line to get our bends/measurements right
then we started bending
floor (changed at a later stage):
the ''sidewall'':
Unfortunately at times the pictures skip a few steps as i hadn't thought as far as a build thread at the time but we then made two hoops for make and front of the ''cab'', and more tubes to join top and floor together
im just going to add all of the frame is made with 42mm mild steel tube and the main bracing done with 33mm mild steel tube.
so we got as far as this:
Progress slowed down considerably after this as i was back to school dad was busy at work and the search for suspension/steeering set-up began.
Thats all i have time for at the moment, ill update asap once i refresh my memory and sort out picture, this build is probably 90% finished and is driving at last
comments/opinions/suggestions are welcome and il do my best to answer questions..
Old 06-20-2012, 07:42 AM
Nodroz's Avatar
Nodroz Nodroz is offline
That looks pretty cool! Do you have any picture of the engine?
Old 06-20-2012, 08:03 AM
JamieH's Avatar
Junior Member
Quote:
Thanks Nodroz! Yes have over 200 pictures of it altogether just want to sort out whats what first, ill try put up picture of engine/ update next stages in the next 2 or 3 days
Old 06-20-2012, 09:20 AM
exenos's Avatar
exenos exenos is offline
Project Nut
Wow, that's not a lot of power coming from a 1.4L. Would have thought it would come in at just over 100hp.
Asides from that, the kart looks good, am I safe to assume that your going to brace the side frame?
Old 06-20-2012, 09:51 AM
JamieH's Avatar
Junior Member
Its plenty to be getting on with for a sunny, especially if its as light as i hope il be looking at 160hp/tonne which is plenty for the space i have over here.
Thanks yes thats all done just need to sort out pictures and what order things came in from there on, a safe frame was one of the main priorities
Old 06-20-2012, 10:06 AM
Bluethunder3320's Avatar
Bluethunder3320 Bluethunder3320 is offline
i wanted to do this with a Isuzu G200 engine (about 90 HP) but the engine was too far gone i ended up scrapping it
  #7
Old 06-20-2012, 10:39 AM
KieranM's Avatar
KieranM KieranM is offline
Doin It!!
Looking well Man
  #8
Old 06-20-2012, 10:50 AM
JamieH's Avatar
Junior Member
Quote:
nothing better than using old parts to make something better unfortunate im sure something else will turn up
Quote:
Originally Posted by KieranM View Post
Looking well Man
thanks man may get the rest up soon
  #9
Old 06-21-2012, 06:05 AM
JamieH's Avatar
Junior Member
Ok so time to continue..
After getting the basic frame done we decided the front suspension was next up, i picked up a 1988 nissan micra for small money and we used the wishbones,shocks,hubs and steering rack out of this with a custom spring setup. We decided to use dimensions as close to the micra as possible to try and keep the geometry right (unfortunately the wheel base is too long for micra geometry causing understeering problems down the line ) to get the right width we had to make the bottom part of the frame narrower,
anyway time for some pictures
Wishbones mounted and some bracing can be seen in main frame:
made shock mounts:
you might be able to see how its heigth adjustable mount:
next we added the steering rack + arms:
picture of wishbone mounted:
then came steering column, wheel + pedals:
then it got front grille/bull bar and we threw on wheels to see how spring rates were:
as you can see the wishbones are at a severe angle which left very little travel in the shocks and would have givin a very bouncy ride, this meant we had to make a custom spring setup based on formula 3 cars, i dont have any good pics of this but will take one when i get a chance for now though:
you should be able to see the bar sticking up with all the holes, this is welded to both the wishbones, when the wishbones move up these bars swing inwards pushing a 33mm tube into a 42mm tube on which the spring is mounted. the multiple holes are to give the wishbones more or less mechanical advantage over the spring and the compression on the spring can also be adjusted, more pics of this to follow.
A back axle was next up which was sourced from a renault 19 we used this as it had a torsion bar eliminating the need for springs leaving more space and because it was heading for scrap anyway. i cut off the back hubs from the 19 and then bolted on the front hubs (rotated forward 90 degrees) then worked out tracking and welded them on the only pictures i have are in with the engine mock up \/
Next up was to mount the engine we first did a mock mount to get positions right and to know what we had to work with for the engine bay:
more to follow as usual comments/questions etc welcome
  #10
Old 06-21-2012, 06:29 PM
brandongeiger2's Avatar
brandongeiger2 brandongeiger2 is offline
Is that horizontal spring up front part of the suspension system? haha
Dirt Devil Build http://www.diygokarts.com/vb/showthread.php?t=15085
"YOLO"-Carpe Diem for the uneducated
  #11
Old 06-21-2012, 07:21 PM
JamieH's Avatar
Junior Member
Quote:
Yep the two springs on the coilovers were too strong for the light front so we copied the formula 1 etc style where the arc made by the wishbones push the spring in and out
  #12
Old 06-21-2012, 08:38 PM
dpaxson's Avatar
dpaxson dpaxson is offline
wait so is that just one shock/coilover shared between both sides of the front suspension? or do you have one coming from both sides and I just can't see the other one in the pictures
  #13
Old 06-22-2012, 11:39 AM
JamieH's Avatar
Junior Member
Quote:
there is two shocks mounted in normal position and then a shared spring between both
Closed Thread
