Closed Thread
Old 06-05-2012, 01:44 AM
Acavet Acavet is offline
Default What CC size motor equals what hp?
In the old days small engines where rated by their horse power. Most mini-bikes and go karts had 3-5 hp engines. Some of the larger karts and bikes had 8-10 hp. Today most of the engine manufactures are not giving the HP rating of the motors just the size of the motors in CC's.
Can anyone provide a breakdown of what CC motor equals approximately what horse power?
Thanks.
Old 06-05-2012, 01:46 AM
landuse's Avatar
landuse landuse is offline
Thanks.
Unfortunately, there is no equation for converting the two. There is no relation that you can use to work it out.
Do a bit of googling, and you will see that it is impossible.
I also used to think that there was some conversion, but there isn't
Old 06-05-2012, 01:49 AM
#1MWD #1MWD is offline
Junior Member
Here is an approximate cc to horsepower chart for small engines. This chart ONLY gives an IDEA of how much horsepower CAN BE achieved by a stock engine of that CC size. There are too many variables, such as carb size, muffler flow, timing, valve duration.
123 cc = 4 hp
179 cc = 5 hp
208 cc = 5.5 to 6 hp
277 cc = 7 to 8 hp
291cc = 9hp
305 cc = 9 to 10 hp
342 cc = 11 to 12 hp
357 cc = 13 hp
420 cc = 13-15 hp
The formula that is below only applies to the small newer normally aspirated (carbureted) 4 cycle engines. The ratios change slightly worse with altitude and slightly better with fuel injection and tuning.
Typical new carbureted small engine:
1 x HP per each 25 cc
Fuel injected:
1 x HP per each 22 cc
The Following 2 Users Say Thank You to #1MWD For This Useful Post:
briggsandstratton123 (03-05-2016), landuse (06-05-2012)
Old 06-05-2012, 04:45 AM
fowler's Avatar
fowler fowler is offline
that is about right but gives u a very wide range or just lawn mower engines
my 600cc bike engine is pushing 140hp
my 800cc honda water pump pushes 24hp
That's not an oil leak
It's horsepower sweat
Old 06-05-2012, 05:12 AM
r_chez_08's Avatar
r_chez_08 r_chez_08 is offline
Should be in the shop...
If you have some torque figures you can work it out from that.
My process of thought:
Anyone can drive a fast car, few can drive a car fast.
Old 06-06-2012, 05:29 AM
JHen JHen is offline
If you know the torque you can calculate your HP. Torque (in ft/lbs) times rpm. Divide by 5252. This is your horsepower.
  #7
Old 06-06-2012, 06:01 AM
jman231994's Avatar
jman231994 jman231994 is offline
Quote:
Why divide by 5252? Seems a tad random haha. Thats not the conversion as far as i know. In saying that I work in metric so I dunno
  #8
Old 06-06-2012, 07:15 AM
Nodroz's Avatar
Nodroz Nodroz is offline
I have a 9hp honda engine, which is 270cc. As people said before, it's hard to decide how much hp an engine has if you know the cc.
  #9
r_chez_08's Avatar
Yeah that calculation is correct. Have a look at this for why.
And read this. A few examples of why displacement does not always relate to HP.
Closed Thread
