Reply
Old 06-04-2012, 08:50 PM
invader gokart invader gokart is offline
Default 9t torque converter what rear sprocket?
I have a comet torque converter 9t for my mini bike how many tooth should my rear sprocket have? 60t or 70t , my engine is a b&s 8HP.. Thanks
Old 06-04-2012, 09:35 PM
Will a 62t or 63t
Old 06-05-2012, 12:39 AM
landuse's Avatar
landuse landuse is offline
Quote:
Will a 62t or 63t
Those sprockets should be fine. You could probably also go down to somewhere round a 50T sprocket. You can generally gear a little higher if you have a TC.
You can have a look at this thread to get some idea.
http://www.diygokarts.com/vb/showthread.php?t=16353
Your gearing would be (axle sprocket/9T) = ?:1
Last Build: http://www.diygokarts.com/vb/showthread.php?t=11334
We are what we repeatedly do. Excellence, therefore, is not an act but a habit-Aristotle
The Following User Says Thank You to landuse For This Useful Post:
invader gokart (06-12-2012)
Old 06-11-2012, 02:13 AM
Ok thanks for reply.. Im actually goin with a tc. 9t and a jackshaft plus the 60t axle sprocket,.. What would be good for my jackshaft how many tooth ?
Old 06-11-2012, 02:14 AM
r_chez_08's Avatar
r_chez_08 r_chez_08 is online now
Should be in the shop...
How big are your rear tyres.
My process of thought:
Anyone can drive a fast car, few can drive a car fast.
Old 06-11-2012, 02:17 AM
10”
  #7
Old 06-11-2012, 02:31 AM
I would like for my engine to Get good torque meaning take off and good to speed,.. Basically I want it pretty evened out as possible. Thanks for the help
  #8
Old 06-11-2012, 04:03 AM
Fabroman's Avatar
Fabroman Fabroman is online now
Correct me if I'm wrong (torque converters are one thing I know very little about) but isn't the driven on a jackshaft with the 9t?
If so then all you need to do is go direct to the rear axle.
There's no better feeling than seeing something you made work
Nothing is impossible to fix if you have enough time, money & patience
  #9
Old 06-11-2012, 04:38 AM
r_chez_08's Avatar
You do realise your rear sprocket would be 9.5" if a 60t and #40 chain, right?
You can gear for much more speed.
With a 70t (too large to fit) you would only go 14mph @3600rpm.
I suggest you get a 10t sprocket for your TC, because axle sprockets are hard to find in lower teeth than 54 with #40 chain. I have a 10t comet sprocket for sale if you want it.
You may have better luck with #35 though. The racers use #35 a lot so there are a wide range of sprocket sizes available. You can get a range of #40 sprockets here, but they are expensive!
Or even get bigger rear tyres.
  #10
Old 06-11-2012, 09:08 AM
Thanks for the help.. So run a #35 chain with 10t on my tc how bout my jackshaft? 10t as well? I need a js. To fit my rear wheel better ..
  #11
Old 06-11-2012, 09:12 AM
Sorry I didint mention its for my mini chopper project
  #12
Old 06-11-2012, 01:39 PM
r_chez_08's Avatar
You have a jackshaft? sorry missed that.
Run #40 from engine to jackshaft. Use the 9t on your tc since you have it.
How big is your jackshaft?
Then run #35 from jackshaft to wheel, you can get a large #35 sprocket for the jackshaft hereYou can get nice #35 sprockets here and the smallest is just over 6"
What top speed are you heading for?
The Following User Says Thank You to r_chez_08 For This Useful Post:
invader gokart (06-11-2012)
  #13
Old 06-11-2012, 04:27 PM
Ok so my tc has 9t to js 10t #40 then 10t to rear axle 60t #35 is thar a good set up?? Im looking fo good take off and good top speed im, trying to get as much HP and speed out of my engine..
  #14
Old 06-11-2012, 05:59 PM
Fabroman's Avatar
Why not just go from the 9t to a 60t on the axle, that would be spot on
  #15
Old 06-11-2012, 06:57 PM
I need a jackshaft because my tc to my rear axle don't line up
  #16
Old 06-11-2012, 09:39 PM
Bump..
  #17
Old 06-12-2012, 01:01 AM
what you fellas think on engine gear 9t js in 10t, js out 10 rear axle 43t..?? need help as im getting parts tommorow
  #18
Old 06-12-2012, 01:16 AM
landuse's Avatar
That gives you a ratio of 4.77:1. With a TC I think it should be OK
  #19
Old 06-12-2012, 02:28 AM
r_chez_08's Avatar
If you answered my questions I could help you more...
That gives you 22mph @3600rpm. Helluva lot of torque.
I would go for more like 3.6:1 which is achievable by 9t:10t then 13t: 43t
You would get 30mph. What sorta terrain are you on?
  #20
Old 06-12-2012, 09:49 AM
Ok chez 08, im getting my js today so I need a good set up so I won't buy more sprockets down the road, so my top speed i'm trying achieve is about 40, 44mph.. Im goin to be in even road, thanks
Reply
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
