Reply
Old 05-18-2012, 06:08 PM
tx7750680 tx7750680 is offline
Default 16 HP duramax engines $229 on ebay
Saw a 16hp duramax engine with electric start for $229 shipped. Are these engines any good? Do they make go cart clutches to go on a engine of this type?
Old 05-18-2012, 07:07 PM
Jcotz's Avatar
Jcotz Jcotz is offline
...wasn't there
These engines are cheap and tend to be reliable. You will need a 1 inch clutch to fit the shaft.
"There is more stupidity than hydrogen in the universe, and it has a longer shelf life."-Frank Zappa
Old 05-18-2012, 07:17 PM
They also have a 7HP electric start for $129 shipped. Anyone tried this one. Unbelievable value
Old 05-18-2012, 07:24 PM
Brandon1023's Avatar
Brandon1023 Brandon1023 is offline
needs an oil change
I'll just add to Jcotz's post here since I have a 13 HP with a 1" output shaft. The clutch is going to be much bigger (~2x the weight of a small one). If you buy a new one, it's probably going to smoke a bit and that is normal, because it's burning off the excess lubrication from the factory. HOWEVER, it shouldn't smoke after a couple rides. If it is still smoking, you need to check your gear ratio. The clutch will just slide right on (Put some grease or a small drop of motor oil on the end of the crankshaft beforehand) and is locked in place with a key that slides in between the clutch and the keyway. Hope this helps a bit.
Old 05-18-2012, 07:25 PM
rcarteraz07 rcarteraz07 is offline
They have dropped the prices on these.
Old 05-21-2012, 07:50 PM
Slash4 Slash4 is offline
WOW! I wish I had an electric start! So is the 7hp any good? Any one know if its possible to put the starting parts (Im assuming the key) remotely, say like on the "dashboard"?
Reply
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
