Go Back   DIY Go Kart Forum > Building Plans And Advice > Photo Gallery & Project Log
Reply
Old 04-23-2012, 09:00 PM
mysteryboy28's Avatar
mysteryboy28 mysteryboy28 is offline
Default Project: go-kart diet!
Time to trim the fat off the big go-kart, make it lighter, nimbler, quicker, have a better turning radius with easier steering, and maybe even look cooler!
Will be chopping the whole front end off and simplifying the suspension to a single A-arm setup, removing the fake triangles on the back (purely there for appearance, offering no structural support) and replacing them with a little cargo rack. Will also be removing the HEAVY thick floor pan (must be 1/4 thick!) and replacing that with sufficiently thick sheet metal.
Let's see how this goes!
Old 04-23-2012, 09:04 PM
Got a good start on the project tonight, here you go!
As you can see, I put everything in a pile that was removed. It must all weigh a good 150 lbs!
Old 05-02-2012, 12:55 AM
Front end is starting to shape up!
I'm afraid that the steering is going to have to take a hit on the Ackerman front... if I do Ackerman geometry then the tie rods will be in the way of the pedals. I will explore the concept of making the tie rods longer and bypassing the center of the steering shaft.
Old 05-02-2012, 05:00 AM
Nodroz's Avatar
Nodroz Nodroz is offline
Looks like you're up for a nice project. Are you going to re-paint it, or will you leave it like that?
I'm using Tie Rods for my steering also. I must say it's pretty easy to adjust them to get the wheel perfectly lined up.
Old 05-02-2012, 06:19 AM
fowler's Avatar
fowler fowler is online now
I will have a bad turning radius without Ackerman
My buggy has no Ackerman and the wheels just take turns at bouncing when I push it on cement
Buggy building Fast, reliable, cheap
Pick two
Old 05-02-2012, 06:36 AM
mph mph is offline
What size tubing did you use? Looks really thick.. heavy but strong
  #7
Old 05-02-2012, 08:14 AM
Jake.B Jake.B is offline
Well considering theres a roll bar it needs to be? If you roll it you need to be sure it wont fail.
IF YOU WANT SOMETHING DONE RIGHT, DO IT YOURSELF
  #8
Old 05-02-2012, 09:42 AM
it's mostly just dirty from riding in the mud. probably should have washed it before i decided to tear it apart. lol. will be painting the areas i work on for sure.
  #9
Old 05-02-2012, 09:45 AM
Quote:
1 inch square tubing for the frame, approx .01 thickness (just under 1/8"), and some 1 inch round tubing for the rollcage, about 1/16" thick. probably should have used thicker tubing for the rollcage, but it was what i had on hand. salvaged it from another kart. lol. i WILL be reinforcing the rollcage with some cross braces.
Reply
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
