#41
#42
I like the roll cage but I think it could use some reinforcing. put some triangle / X shaped crossbars on the top.
something kinda like this...just food for thought.
It's hard to help people that won't help themselves. |
#43
I agree that it will need some crossbars for reinforcing. You also need to get a safety belt on that thing
Nice work though
Last Build: http://www.diygokarts.com/vb/showthread.php?t=11334 We are what we repeatedly do. Excellence, therefore, is not an act but a habit-Aristotle |
#44
I 100% agree. The "quick cage" was done more for cosmetics, in an effort to sell it faster. But I think my conscience will get the best of me and I'll be throwing the reinforcements on.
#45
Some padding for the roll cage...
Was also having trouble with the 40 chain kinking up and the master link hitting the clutch in a bad way - till the chain finally separated at some point and came undone. Bought a 41 chain, made a world of difference (10 feet of it for $20 at Tractor Supply, versus $10 + shipping for 70 links at BMIkart.com, not recommended). Nice and smooth now.
#46
I'm a senior member! Yay!
#47
what was your total cost on the project if I may ask?
#48
I received the rear axle, big tires, brake caliper, and 60 tooth sprocket for free with a previous kart I had purchased. Between metal, BMIkarts.com, MFGsupply.com, Home Depot, Tractor Supply, Harbor Freight... I'd say I've got about $380 into it, including welding wire/grinding discs/etc.
#49
Thats not bad at all, and the kart looks good too. I hope you prepared the $600 price tag with some haggle room though.
Oh, and I have been meaning to ask where in Lansing you live, my mom grew up on Seymour Street in Lansing and a few of my uncles live around there.
#50
Is that a minibike I see in one of those pics
#51
yes sir! for sale for $220 with a good running 151cc Kawasaki motor in it.
leaks a little gas from the carb if you lean it to the right, and the footpegs are a little low (scrape the road a lot when you turn, but an easy fix). comes complete with bungie cord to strap the gas tank to the frame! lol.i did the governor bypass trick on the mini-bike, replacing the spring with a straight piece of coat hanger wire. thing goes 30+ mph with me on it. yee-haw! figured it's a Kawasaki - it can take it! |
#52
you have a nice well built clean go kart! someone should snatch that up soon! good job on the build!!
Obstacles don't have to stop you. If you run into a wall, don't turn around and give up. Figure out how to climb it, go through it, or work around it. ~ Michael Jordan |
| The Following User Says Thank You to gokart14 For This Useful Post: | ||
mysteryboy28 (04-24-2012) | ||
#53
Quote:
| Thread Tools | |
| Display Modes | |
