Reply
Old 07-01-2008, 05:24 PM
Magice's Avatar
Magice Magice is offline
Default Clearance for kt100.. and a few questions
I've just bought a kt100 for $100. Picking it up Wednesday.
Now as you know the pto is on the other side with a 2 cycle, so I'll have to mount it pto right, away from the kart.
There is very little clearance between the wheel and the frame for the sprocket, so I was wondering. Should I mount it with like about 1cm of clearance on either side after the chain, or should I invest in a jackshaft setup.
My other question was does the kt100's crankcase come tapped for a pulse fuel pump, and does the walbro carb have a pulse fitting.
Also, on a side note, 2 strokes get power from compression in crankcase, wouldn't a pulse pump bring compression down?
Old 07-01-2008, 06:47 PM
Russ2251's Avatar
Russ2251 Russ2251 is offline
Reed Valve Ranger
This is true of KT-100's, not 2 cycles as a whole.
Crankcase is tapped for diaphragm carburetor as standard for this engine. Carb has nipple for this reason. Probably a WB-32 or WB-3a Walbro.
This is incorrect. 2 cycles get power from fuel air mixture in combustion chamber, same as a 4 cycle. Pressure in crankcase is necessary to get fuel/air mixture into combustion chamber via ports in cylinder wall/piston.
Typically, these engines are race ready and require rebuilds every 100 miles or so. Definitely not for the inexperienced builder. Many books out that cover this engine. I strongly recommend you check them out.
Insignificant. Too small to measure.
Opportunity always knocks at least once...Rarely does it knock twice.
Old 07-01-2008, 07:44 PM
Kenny_McCormic Kenny_McCormic is offline
Kartless....
Should have enough by the sound of it, most minibikes are setup that way.
Old 07-01-2008, 10:23 PM
Magice's Avatar
Russ being the 2 stroke expert you are what kind of decreases would I see in the engine if it wasn't rebuilt?
I'm not sure if I'm going to put this on my kart or not. I'm not going to be racing.. But for $100 and close I couldn't resist the kt100 + clutch.
Old 07-02-2008, 12:37 AM
Magice's Avatar
Any particular book you recommend?
Old 07-02-2008, 06:52 PM
Russ2251's Avatar
Reed Valve Ranger
Thanx, but still learning just like you! I'm just on a different level.
Expect mushy compression. Rings are first thing to suffer wear. May be fine the way it is but will not be giving you the 9 or so horse power it's rated at.
The factory service manual for starters. Contact Yamaha or go to their website and see if they have a manual for download.
If you do contact them, have serial number ready. These engines are subject to new revisions year to year.
A '92 model might have different specs than a '96.
Side note: Surprises me that this is a piston ported engine when it is well known that reed inducted engines rev higher with better response time.
  #7
Old 07-02-2008, 07:11 PM
Magice's Avatar
What's the difference between piston ported and reed inducted?
  #8
Old 07-02-2008, 07:18 PM
Kartless....
Quote:
How the intake is closed off from the carb to produce pressure that pushes fuel into the jug. Piston ported:the piston covers the port its cheaper and more reliable, reed inducted: uses a one way reed style valve. Im curious how they designed a engine that only lasts for 100 miles? Lean running or crap materials?
  #9
Old 07-02-2008, 07:48 PM
Russ2251's Avatar
Reed Valve Ranger
On piston ported, shirt on piston acts as a valve to open and close intake port.
Reed valves are metal leaves (or petals) that open in the presence of negative pressure or partial vacuum as piston moves upward in cylinder (intake stroke).
When piston moves downward, it pressurizes crankcase forcing reed valves to close.
Open in one direction and close in other direction.
Vacuum opens. Pressure closes.
Most 2 cycle engines use metal reeds while high performance engines use carbon fiber.
pic 1: reeds in partial vacuum.
pic 2: piston ported. blue = intake red = exhaust
  #10
Old 07-02-2008, 07:56 PM
Magice's Avatar
Quote:
Well it can spin 18k rpm..
  #11
Old 07-02-2008, 08:14 PM
Russ2251's Avatar
Reed Valve Ranger
Full size dragster engines good for 1 1/4 miles or 5 races if they manage to stay together at all.
"The light that burns twice as bright, burns half as long" Eldon Tyrell
  #12
Old 07-02-2008, 08:18 PM
Magice's Avatar
I might play around with this a little.. Then see if I can sell it / trade it for a 125cc shifter engine or something like that. It seems to be tooooo fragile.
I might consider direct drive though.
  #13
Old 07-02-2008, 08:27 PM
Russ2251's Avatar
Reed Valve Ranger
Just a question out of curiosity. Did you get a starter with this engine? If so, what is it?
Kick?
Electric?
What is compression (psi) ?
  #14
Old 07-02-2008, 10:10 PM
Magice's Avatar
I know nothing about the engine except that it runs and it comes with a clutch.
  #15
Old 07-02-2008, 10:13 PM
Russ2251's Avatar
Reed Valve Ranger
Mount it on something just for S & G's!!!
  #16
Old 07-02-2008, 10:23 PM
Magice's Avatar
I have a friend who's picking it up today. He isn't home, I'll probably have it tomorrow.. I'm excited
I wish I had a place to take it to top speed. The main road is just too dangerous.. People pulling out of driveways ,etc.
  #17
Old 07-03-2008, 07:33 AM
jr dragster Tyler's Avatar
jr dragster Tyler jr dragster Tyler is offline
They last longer than that, russ. your refuring to like 4000 horsepower blown alcohol that MAYBE last 5 runs. Or top fuel engines are REBUILT every run within 2 hours.
  #18
Old 07-03-2008, 08:11 AM
kibble's Avatar
kibble kibble is offline
I banned myself
Quote:
Originally Posted by jr dragster Tyler View Post
They last longer that that russ. your refuring to like 4000 horsepower blown alcohol that MAYBE last 5 runs. Or top fuel engines are REBUILT every run within 2 hours.
LOL! You need to use a comma between "They last longer than that" and "Russ". The first time I read it, I thought you were saying that it lasted longer than Russ. I had to go back and read it again.
I wanna see pics of this engine when you get it!
"At the enrichment center we believe that if at first you don't succeed, you fail." GLaDOS - Portal
  #19
Old 07-03-2008, 05:10 PM
Russ2251's Avatar
Reed Valve Ranger
Makes no difference. You're missing the point of post.
Here's Yamaha's website:
http://www.yamaha-motor.com/sport/pr...64/0/home.aspx
Reply
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
