i need a cheap one cause i used all my money to buy the mini bike and the asshole gave me a motor that had the card thead holes stripped out.
i live in bakersfield buy the way |
retap the holes
you mean the carb holes? If so you have ALOT of repairing options. Re-tap it. Heli Coil it, Drill it out and tap the new bigger hold and drill bigger carb holes, Drill it out a bit and JB weld in threaded rods and use nuts to hold it on.
Buy a $30 heli coil kit, plug off the intake, tap and install, go play.
$30 for a helicoil kit? You could get a Briggs 2HP motor on eBay for that!
Shipped?
#7
Probably not, but these a days, you could get a Briggs 2-3 horse that runs great for $40-$50 shipped. Back then, it was $30 shipped, seeing as I have a few of them myself.
#8
I like Tyler's idea of hogging out the holes and JB-Welding a pair of studs in place. We did it on a friend's Mazda Pickup (themostat housing) and it worked beautifully. When you drill out the hole oversized, carefully hog out the deep part of the hole with a dremmel a little wider... when you pack it in with the JB-weld, it forms a sort of Keystone that'll make it stay in there pretty well. But always keep your eye for cheap engine buys too, can never have enough!
When it gets scary, it's almost Fast Enough! |
| Thread Tools | |
| Display Modes | |
