Reply
Old 06-26-2008, 11:34 AM
Yooper Knight Yooper Knight is offline
Junior Member
Default Rear Axles
OK from what I have seen on this and some other forums......... The rear axle is threaded for what ? screw on a hub ? or bolt to keep the wheel from coming off ? I am so confused as usual
Red
Old 06-26-2008, 12:25 PM
kibble's Avatar
kibble kibble is offline
I banned myself
I think it's yes and yes, depending on your purpose. In my case, I'm using them to hold the rear hubs on with a nut on each side.
"At the enrichment center we believe that if at first you don't succeed, you fail." GLaDOS - Portal
Old 06-26-2008, 09:58 PM
Kenny_McCormic Kenny_McCormic is offline
Kartless....
Usually holds hubs on.
Reply
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
