Closed Thread
Old 01-10-2012, 11:52 PM
darce darce is offline
Junior Member
Default Engine idles but dies when i give it gas.
I have a subaru robin ex17. The engine starts up good .idles a little crappy but when i give it gas it dies. MIKUNI CARB
I believe its a carb problem because when i give it gas white mist/smoke shoots out of the carb also every one and a while it shoots out white smoke out the exhaust.
I know very little about go karts any thougts would help.
Thanks
Old 01-11-2012, 12:19 AM
landuse's Avatar
landuse landuse is offline
I would give the carb a thorough cleaning first, making sure that you poke out all the holes with a bit of copper wire or guitar wire. Twist ties also work well. You can also use compressed air to try clean the passageways.
You can also boil the carb in lemon juice to try and get all the gas 'varnish out of the carb. Dont boild the rubber seals and gaskets though
Latest Build (Will not complete): http://www.diygokarts.com/vb/showthread.php?t=23363
Old 01-13-2012, 10:15 PM
Junior Member
i just did this i cleaned every little spot in the carb. Any other suggestions?
Old 01-13-2012, 10:52 PM
Russ2251's Avatar
Russ2251 Russ2251 is online now
AZUSA LAWN-BOY E
Quote:
when i give it gas white mist/smoke shoots out of the carb...
Could you also call it a vapor that quickly disappears? If so, may be a rich condition.
Pic of carb?
https://youtu.be/c4jch0puM1A
Old 01-14-2012, 02:38 AM
Grimace Grimace is offline
Mr. Furious
Try running the engine with the choke halfway closed. I have to do this when I run my weedeater on fuel with ethanol in it. Not sure why, but it runs really well when I do.
Old 01-14-2012, 08:49 AM
Russ2251's Avatar
AZUSA LAWN-BOY E
Quote:
You are describing a very lean condition. Clean and/or open up jets.
Weedie carbs have a fine mesh screen/filter that when clogged will produce said leanout.
  #7
Old 01-14-2012, 12:28 PM
Mr. Furious
It doesn't seem to do it after a tank of 100% gas, no ethanol. Of course the weedeater has had a hard life, several summers of commercial mowing, and property clearing.
  #8
Old 01-14-2012, 02:27 PM
sexyvicta sexyvicta is offline
^dont run twostroke weedeater with ethanol fuel.
  #9
Old 01-17-2012, 10:38 PM
Russ2251's Avatar
AZUSA LAWN-BOY E
All gasoline in the states has a percentage of ethanol.
  #10
Old 01-17-2012, 10:46 PM
souperman000's Avatar
souperman000 souperman000 is offline
might be a stupid question....but did you include the oil in the mix?
Just making sure
  #11
Old 01-17-2012, 11:33 PM
fmjnax fmjnax is offline
Junior Member
What does the plug look like? That could give an indication of what the fuel ratio may be (lean/rich). I agree that it sounds lean.
As for asking about the oil mix, I doubt that would be the problem - my knowledge with small engine 2-strokes is limited, but at least in marine 2-strokes (where my experience comes from), if you don't have the proper oil mix, your engine isn't going to last long at all (minutes, if you're lucky)!
  #12
Old 01-17-2012, 11:47 PM
This is true, but you never know,
  #13
Old 01-18-2012, 12:12 AM
landuse's Avatar
Quote:
Pic of carb?
As Russ said, post a pic of the carb
  #14
Old 01-18-2012, 10:08 AM
Mr. Furious
Not all gasoline here in the states has ethanol. Here in Oklahoma, they have to put a sticker on the pump saying it contains ethanol. Some gas stations have signs saying 100% gasoline, no ethanol. That's where I usually fill up. And yes, there is oil in the gas. I am an aircraft mechanic and build racecars on the side. I know engines, and used to work in a machine shop building engines and heads for a living.
  #15
Old 01-18-2012, 02:35 PM
Russ2251's Avatar
AZUSA LAWN-BOY E
You are one of the very, very few and will change shortly.
  #16
Old 01-20-2012, 03:57 AM
yeh but grimace can get 100LL for free if he saves all the dregs from the planes he works on no ethanol in that
  #17
Old 01-20-2012, 06:17 AM
Mr. Furious
Very true. Long term effects of running leaded fuel are also bad though. Even though it says "Low Lead" it still has more lead in it than the old "Regular" gas had back in the day.
  #18
Old 01-20-2012, 01:47 PM
What are the negative effects of avgas? I can prob go and get a bit for free aswel/will have water in it. I think the freeness cancels out the bad tho lol
  #19
Old 01-20-2012, 03:24 PM
Junior Member
Thanks alot guys i figured it out.
People sure do get off topic here
  #20
Old 01-20-2012, 03:52 PM
Doc Sprocket's Avatar
Quote:
So... What was the problem?
LOL. That was nothing!
Closed Thread
