Go Back   DIY Go Kart Forum > Building Plans And Advice > Photo Gallery & Project Log
Closed Thread
Old 06-09-2008, 05:16 PM
sayre315 sayre315 is offline
Rupp enduro
Default 31cc trike
i found a 31cc RYOBE weedeater not vary big but if i can get it at 1000rpm with me on it the speed calculatar sais that is will go 9mph
Old 06-09-2008, 05:18 PM
Rupp enduro
the pics i took wont work so i will have to try getting them on later
Old 06-09-2008, 05:24 PM
Kenny_McCormic Kenny_McCormic is offline
Kartless....
A weedeater revs at over 5k, makes 1 hp if your lucky.
Old 06-09-2008, 05:33 PM
Russ2251's Avatar
Russ2251 Russ2251 is offline
AZUSA LAWN-BOY
Quote:
I once got a bicycle to do 15 mph with the Ryobe using a rather unorthodox (my middle name) drive system. Someday I'll re-assemble it and post some pics.
https://youtu.be/Rzf-Kl352LI
The Following User Says Thank You to Russ2251 For This Useful Post:
sayre315 (06-09-2008)
Old 06-09-2008, 05:35 PM
Rupp enduro
i belive it is a 1-2 gear ratio
leme look real fast
Old 06-09-2008, 05:36 PM
Rupp enduro
yes
its a 1-2 gear ratio
from a bike
  #7
Old 06-10-2008, 12:48 AM
modelengineer modelengineer is offline
Lord of the noise
For a weedeater motor to work at any reasonable acceleration you will probably need about 20:1 ratio, and this wont give very good top speed.
Andrew
GS500F powered...
  #8
Old 06-10-2008, 01:11 AM
robertdjung's Avatar
robertdjung robertdjung is offline
Administrator
Can you describe the system briefly, russ? Sounds intersting!
  #9
Old 06-10-2008, 04:52 AM
Russ2251's Avatar
AZUSA LAWN-BOY
Quote:
Can you describe the system briefly?
I'll give you a hint. In my research, I discovered that this was first attempted in 1911 with a multi-cylinder engine. Stay tuned...I smell a new thread in the coming weeks.
  #10
Old 06-10-2008, 07:30 AM
oscaryu1's Avatar
oscaryu1 oscaryu1 is offline
Pie es bueno
Friction drive?
  #11
Old 06-10-2008, 09:28 AM
Rupp enduro
im not realy looking for anything higher than 10mph at the most
its just sitting in my garoge and collecting dust
and the trike is like a 2 year olds trike
i'll try to get some pics up
  #12
Old 06-10-2008, 10:20 AM
oscaryu1's Avatar
Pie es bueno
10MPH? Gear it REALLY low or get a TAV.
  #13
Old 06-11-2008, 04:00 PM
Rupp enduro
russ
how did you you gear it
friction
sproket?
how?
  #14
Old 06-11-2008, 04:23 PM
Russ2251's Avatar
AZUSA LAWN-BOY
None of the above. Will post in coming weeks when re-assembled.
  #15
Old 07-12-2008, 06:09 PM
Russ2251's Avatar
AZUSA LAWN-BOY
As promised:
http://www.diygokarts.com/vb/showthr...5946#post15946
Closed Thread
