Go Back   DIY Go Kart Forum > Other Stuff > For Sale or Trade
Reply
Old 06-06-2008, 04:45 PM
megaman1339 megaman1339 is offline
weedeater-bike builder
Default I need an inexpensive gokart engine
doesnt need to be much just like 4 hp something like that, and i dont care if it is as old as dirt or brakes noise violations it just has to run.
Old 06-06-2008, 04:56 PM
kibble's Avatar
kibble kibble is offline
I banned myself
Have you tried checking your local Freecycle group or craigslist? You can get some decent free stuff from other people on there.
"At the enrichment center we believe that if at first you don't succeed, you fail." GLaDOS - Portal
The Following User Says Thank You to kibble For This Useful Post:
megaman1339 (06-06-2008)
Old 06-06-2008, 05:12 PM
no i hadnt, but i will
Old 06-06-2008, 08:58 PM
Kenny_McCormic Kenny_McCormic is online now
Kartless....
Just ask for anything with a horizontal shaft running or not.
Old 06-06-2008, 10:51 PM
why not running?
Old 06-07-2008, 02:04 PM
jr dragster Tyler's Avatar
jr dragster Tyler jr dragster Tyler is offline
Because if it doesnt run you can pretty much bargain it down to nothing. And normally the only thing wrong with these engines is a simple carb clean or a spark plug Etc.
  #7
Old 06-07-2008, 08:53 PM
Kartless....
Quote:
Corroded points are common one as well.
  #8
Old 06-08-2008, 07:06 AM
I was going to say somthing like a coil and the points but just to keep it simple untill he actually has to worry about that I never mentioned it.
  #9
Old 06-08-2008, 08:51 AM
I like karts's Avatar
I like karts I like karts is offline
Rotary Power!
yeah there not really much that can go wrong in these engines cause they have only ....*counts on fingers*.... 5 moving parts in a briggs flathead, not counting the valves and lifters and stuff cause they just move up and down.
It'll be simple to fix.
  #10
Old 06-08-2008, 01:01 PM
oscaryu1's Avatar
oscaryu1 oscaryu1 is offline
Pie es bueno
What's to worry about points? Cut the wire off and replace it with a magnetron
  #11
Old 06-08-2008, 01:07 PM
Kartless....
Quote:
When somebody drops a nuke, dont come whining to me about your stuff not running.
  #12
Old 06-08-2008, 07:04 PM
is it hard to alter a vert-shaft to run in horizontal?
  #13
Old 06-08-2008, 07:36 PM
oscaryu1's Avatar
Pie es bueno
Carburetor, dipper, bracket/mounts...
  #14
Old 06-08-2008, 07:38 PM
Russ2251's Avatar
Russ2251 Russ2251 is offline
Reed Valve Ranger
Not for me!!! LOL
Opportunity always knocks at least once...Rarely does it knock twice.
  #15
Old 06-08-2008, 07:42 PM
Do all small engines have points? I do not fully understand what it does. Because on my jr dragster all I have is a wire off the coil going to the spark plug?
  #16
Old 06-08-2008, 07:44 PM
The 2 wires off the coil are for normall kill switch and emergency kill switch. So without points does that mean that every time the magnet goes past the coil it sparks the plug? That would mean it "wastes" a spark because it only actually ignites fuel ever 4'th stroke.
  #17
Old 06-08-2008, 07:57 PM
Russ2251's Avatar
Reed Valve Ranger
Virtually all engines use breakerless (without points) systems and use CDI or Capacitive Discharge Ignition. Requires little or no maintenance.
If you had points in your engines, performance would suffer greatly.
  #18
Old 06-08-2008, 09:23 PM
plz tell me how to alter it, but use words i can understand!
  #19
Old 06-08-2008, 09:27 PM
also i fanyone has a vid of how to tell me where
  #20
Old 06-08-2008, 09:41 PM
Russ2251's Avatar
Reed Valve Ranger
Clutch alone is $129. You can buy a new engine for that amount.
Reply
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
