Closed Thread
Old 10-29-2011, 12:58 PM
aj'77 aj'77 is offline
Junior Member
Default 110cc chinese engine
I have a taotao go kart with a 110cc chinese engine and im lookinf for a manual. Does anyone know where to get one?
Old 10-29-2011, 04:39 PM
racerc2000 racerc2000 is offline
I did a quick search. and it looks like it will be hard to find.
its supposed to come with an owners manual (not much info ive heard)
as for if you are looking for a repair manual
maybe you should email taotao themselves. http://taotao.us/
most Chinese made things wont have much info. as there not made to be rebuilt. but im sure you could if you wanted to.
The Following User Says Thank You to racerc2000 For This Useful Post:
aj'77 (10-29-2011)
Old 10-29-2011, 07:06 PM
Junior Member
I called taotao and they did not have a manual. The engine will not start. I've cleaned out the carb, got spark, and compression. Does anyone have any suggestions. What does a CDI box do and does this engine need to be timed and is it hard to do. It's a 110cc chinese engine with electric start.
Old 10-29-2011, 07:13 PM
Junior Member
Default 110cc chinese engine that wont start
I have 110cc engine that will not start. I cleaned out carb, got spark, and compression. What does a CDI box do? Does this engine need to be timed and if so is hard to do?
Old 10-29-2011, 11:05 PM
Russ2251's Avatar
Russ2251 Russ2251 is online now
AZUSA LAWN-BOY E
Capacitive Discharge Ignition.
If you have spark, you do not need one.
No to both in the case of most small engines. There are exceptions.
https://youtu.be/c4jch0puM1A
Closed Thread
