Closed Thread
Old 06-19-2011, 10:31 AM
Thrahl Thrahl is offline
Junior Member
Default Multiple Problems with Torque Converter
I have a modified Manco Dingo that originally came with a 8 or 10hp engine and a Comet 40 series TC.
The engine was trash so it now has a 5.5hp Honda GX200 clone.
But the new engine has a 3/4 shaft rather than 1" so we went a got a 20 series drive clutch for it, but kept the 40 series driven.
It runs good for a bit but the belt gets stretched out within a few rides and is basically unusable after about 20 hours of use.
The engine is not adjustable relative to the jackshaft so I can't move it back to tighten the belt.
Belts are like $30-40 a pop so I can't afford to just keep putting new belts on.
The belt doesn't look worn at all and has no cracks or frays or anything, it's just stretched.
Is the problem because of my mismatched TC or something else? And what can I do to fix it? (short of buying an $80 20 series driven)
Old 06-19-2011, 11:57 AM
B man's Avatar
B man B man is offline
Tecumseh FTW!
get the correct driven for your driver.
If it doesn't work......well then its gonna!
Old 06-19-2011, 04:34 PM
redsox985's Avatar
redsox985 redsox985 is offline
The 20 series driver uses a 3/4" belt and the 40 a 7/8" belt. Make sure the belt is made for the specific center distance between the driver and driven also. Selling the 40 series TC will easily pay for a 20 series one, but I doubt you'll be happy with 5.5 HP when you used to have 10, in which case, you need the 40 again.
The Following User Says Thank You to redsox985 For This Useful Post:
Thrahl (06-20-2011)
Old 06-19-2011, 06:12 PM
kendelrk's Avatar
kendelrk kendelrk is offline
redneck engineer
5.5 hp is a gx 160 clone isint it? i thought 6.5 was gx 200 clone
Old 06-19-2011, 06:18 PM
Doc Sprocket's Avatar
Correct- Gx160=5.5hp, gx200=6.5hp.
And yes, you need to have matching driver and driven, and the correct pulley center distance.
If you're handy, resourceful, or lucky- you can buy/find/fabricate an adapter bushing to alow you to use the 40 driver on the new engine.
The Following User Says Thank You to Doc Sprocket For This Useful Post:
Thrahl (06-20-2011)
Old 06-19-2011, 07:51 PM
Junior Member
Sorry it took so long to get back I have been busy.
@redsox985 - I have been running it with the 5.5 ever since I got it. The 10hp it came with was nonfunctional (don't know what was wrong with it, was before I cared about this stuff). So I don't know what I'm missing
@kendelrk - I thought so at first but I wasn't sure so I went on the Honda site and saw 4.8 http://engines.honda.com/models/model-detail/gx160. Maybe I am looking at the wrong stat.
@ toystory 4wd - when you say adapter, do you mean 3/4" to 1" adapter for the shaft? I have thought about that but I thought that since the 40 series says it is for 8-18hp it might pose a problem for my 5.5? (though I doubt it would be as bad as my current problem lol)
  #7
Old 06-20-2011, 03:42 AM
Yep- that's exactly what I mean. I'm going to be doing that, too. There's a very good possibility it will work just fine. They do suggest a minimum of 8hp- probably because you just don't tend to see engines smaller than 8hp with a 1" shaft.
EDIT- did you dispose of the 10hp?
Here, check this thread- http://www.diygokarts.com/vb/showthread.php?t=9990
Thrahl (06-20-2011)
  #8
Old 06-20-2011, 09:33 AM
Junior Member
@toystory 4wd - I did a lot of researching last night and figured out what I am going to have to do. Adapting a 40 series on to a 3/4" shaft seems like a somewhat common problem with a fairly easy fix.
Unfortunately yes I did throw the 10hp away. I built the go kart with my father years ago and at the time I didn't know anything about engines. Looking back I should have kept it and I could have possibly got it running again. Oh well though.
And yes I read that thread last night and it was very helpful.
I think I pretty much have all the info I need to give this a shot. Thanks for all of your help guys.
  #9
Old 06-20-2011, 05:18 PM
You're welcome. Good luck.
Closed Thread
